20 Most Recent Amana ABB1927DE Bottom Freezer Refrigerator Questions & Answers
May be the relay on the compressor. Is it cooling properly?
Amana ABB1927DE... | Answered on Mar 05, 2019
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com good luck
Amana ABB1927DE... | Answered on May 19, 2018
Heat guns are typically a bad idea as most people will hold it in one place too long melting,or disfiguring the plastic on the icemaker or worse,the cabinet.
Removing and using hot water is always the best way!
The usual problem for small, or hollow ice cubes is a bad saddle valve. There really isn't a good saddle valve in my opinion as they always clog either from mineral or rusting from the inside out.
What you want to do is find your shutoff valve. Sometimes in the basement, or under a sink if it is close by the refrigerator and look to see how it is hooked up. If it has a valve like the attached pic then it would be best to call in a plumber and have him replace it with a toilet style ball valve which will never restrict water flow and will always work!
The two main types of saddle valves are self pierce (absolute garbage) and drill type. If you look at where the valve straps to the pipe it will either have a round or square gasket. The square gasket ones are the worst and 99.5% of the time are the problem.
Amana ABB1927DE... | Answered on Feb 01, 2018
is there frost building up in the back of the freezer wall?mike
Amana ABB1927DE... | Answered on Dec 14, 2017
A light switch failure can leave the light on even with the door closed, raising the temp. to over 40 degrees. Firstly, make sure doors are not sagging creating a switch activation with the door closed. If that checks good, replace the door switch.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Amana ABB1927DE... | Answered on Oct 07, 2017
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Amana ABB1927DE... | Answered on Sep 09, 2017
You pretty much answered your own question. If the remaining working bulb works in the socket and if the base seems to be not long enough on the replacement bulbs - there is most likely a problem (or by design) - with the bulbs. The best way to be sure is to ensure the correct bulb type - c6, c9 etc.
http://www.appliancepartspros.com/whirlpool-light-bulb-8009-ap3607217.html 40 Watt Appliance Bulb
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
Amana ABB1927DE... | Answered on May 01, 2017
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Amana ABB1927DE... | Answered on Feb 22, 2015
It needs a 30" opening that is 67" High and 33" deep with the handle.
Here is a link to all the specs and more information
http://www.ajmadison.com/cgi-bin/ajmadison/ABB1927DES.html
Here is a link to the manual to help with installation.
ABB1927DES AMANA AMANA REFRIGERATOR Manual
Amana ABB1927DE... | Answered on Feb 18, 2015
Hello if it is leaking black fluid from the bottom of the fridge the most likely fault is the drain hole in the cooler is blocked stopping
the defrost going down to the heater to evaporate ,just clear the hole with a coat hanger wire or something similar
tk
Amana ABB1927DE... | Answered on Nov 14, 2014
Frost free Refrigerators go into defrost cycle every 6-12 hours depending on model.
If frost become visible, on of the defrost system (Defrost timer,Defrost heater, Defrost thermostat) components has failed. The most common failure is the defrost time. If you can locate the time, try to advance it (rotating) into defrost and if you see water coming into the drain-pan within a couple of minutes, than the Heater and thermostat are OK and you need to replace the timer (relatively easy job). If no defrost occur , you better call a tech and avoid replacing unnecessary parts. Caution - Some defrost timer are incorporated into the Ice Maker mechanism are hard to test and must replace the entrie Ice Maker
Amana ABB1927DE... | Answered on Aug 19, 2014
Place the number in BING or GOOGLE search. Amazon or some other will be presented to choose from. Find you part and get an idea of what it will cost you. Look up your nearest appliance parts distributer also. Most times they can offer advice as well. They see it all with their customers. I hope this helps you.
Amana ABB1927DE... | Answered on Jul 30, 2014
Amana ABB1927DE Bottom Freezer Refrigerator Logo
735 questions posted
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
refrigerator door wont close all way
  • Refrigerators
