Cell Phones Logo
A
Al Faulkner Posted on Nov 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set up for printing photos to computer?
Jarin Saba
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 8 Answers
  • Posted on Nov 27, 2015
Jarin Saba
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
8
Questions
0
Helped
1696
Points
22
Go to the pic you want to print and then right click and then print. You will get the screen of customizing before printing . there choose your printer or else it won't work. And then click print.
Danny Kuhlmann
Level 3:
  • Samsung Master 1,443 Answers
Danny Kuhlmann
Samsung Master
Level 3:
Answers
1443
Questions
Helped
262411
Points
4794
Hello, do a right click on the screen of the photo you want too print and click print.
How to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
2answers
My mfc 495cw printer isnt printing photos
Check the printer settings on your computer.If you print a photo on photo paper you have to select photo paper on the printer media type settings.
1helpful
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
2answers
Canon Printer IMAGE QUALITY
use the canon software and set up fax seperately.
Cannot print images with Microsoft Photo Editor
how to set a primary photo in a friendster, i dont know how to set or save a primary photo in a friendster.
2answers
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
Can't print photos onto photo paper from computer
hii
you must check the setting of your printer and then restart the printer.
1helpful
2answers
I cannot scan photographs to computer
hi! there,
well,if you are trying to print a photo under photo album
and you want to select photo or you are to fetch photo, if you click this you are going to menu of your windows exactly, on that you go to my picture,on that menu select your picture to print,if you selected your picture your going back to your photo print menu in this photo print menu it will flash your picture to print,there option there before you print,set all this e.i your photo size 4x6,5x10 or wallet size depend on you,on lay out you have to select how does it print on you photo paper is it 4 pic on one photo paper or 6 etc..the thing is it has you to return in menu in order to flash your photo,this will help you print your own photo no need to go to your photo shop to develop it easy.cheers have a good day thank's to log in fixya don't forget to rate me.
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
2answers
Lines on a photo when printed
The print quality usually depends on the program you're using to print them on your pc.
Your camera only ever sends photos to your printer, so the best settings are already selected by the camera and it's built-in photo program.
Your printer doesn't 'know' whether your printing a document or a photo, so the settings for each program on your computer are basic (known as default settings), and need to be changed by you to get the best from your printer
Find the settings that let you alter the printers options (in Word, it's FILE \ PRINT \ PROPERTIES), and make sure the printer output is set to maximum quality, and that photo paper is selected as the paper type.
Some options such as 'maximum quality' only appear when you've chosen 'photo paper', and some printers (such as the ip4300) have seperate options for gloss or matte paper, so go through all of them until you see what you need.
Hope that helps :)
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
