20 Most Recent Samsung SYNC SGH-A707 Cellular Phone Questions & Answers
2answers
My samsung sync wont charge when plugged into the charger
i am having the same problem with my Samsung Sync (A707). I brought it into AT&T and it is neither the Phone, battery, or charger
11/8/2019 2:45:11 AM • Samsung SYNC... • Answered on Nov 08, 2019
2answers
2009 question doesnt' need a spammer like YO YO (AKA Sammi) Phone lock code Samsung Eternity
All you have to do it type it on your dial screen: #7465625*2877#
11/7/2019 1:30:26 PM • Samsung SYNC... • Answered on Nov 07, 2019
2answers
Samsung A707 phone freeze and
you can contact the service provider...........
10/24/2019 1:19:53 AM • Samsung SYNC... • Answered on Oct 24, 2019
Could you please tell me the samsung unlock code and procedure fortaking off the network lock, its a 3g phone and i wish to put a vodafone sim in it
Hi, Contact your service provider and get the unlock code for your Samsung SGH-A707 from them or else you can get it from online sites. Try Prounlocking.com ,they provide codes at affordable price.Unlocking Instructions:1 - Switch ON your Samsung SGH-A707 with a NOT ACCEPTED SIM Card. 2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#). NOT ACCEPTED:Use a sim card from a network other than the network your Samsung SGH-A707 is locked to. CODE: Its the unique Unlock Code for your Samsung SGH-A707 that you get either from your service provider or from online sites.
10/22/2019 12:22:33 AM • Samsung SYNC... • Answered on Oct 22, 2019
How to transfer contacts frm samsung guru100 broken screen to sim
Try samsung PC Studio software free on their website.
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SGH-A707&mType=SW&vType=L&disp_nm=Sync(SGH-a707)
It works with my sgh-a707 and might work for yours. They might have different software for yours so check that site out. all work is done by computer.
10/16/2019 1:44:50 AM • Samsung SYNC... • Answered on Oct 16, 2019
Can't install jad files from
sorry to say but the files that you may have downloaded may not be supported in your samsung A-707 cellular phone.. samsung phones offer only few files to be run on it..
9/10/2019 4:32:38 AM • Samsung SYNC... • Answered on Sep 10, 2019
3answers
Unlock
unlock my samsung SGH-A707
6/28/2019 1:09:33 AM • Samsung SYNC... • Answered on Jun 28, 2019
Freeze ona a samsung t469
you can get the unfreeze code for your samsung mobile through this site Onlinegsmunlock.com , it provides the step by step instructions and simple methods for getting the code for your samsung mobile at a safe way........
6/25/2019 12:35:26 AM • Samsung SYNC... • Answered on Jun 25, 2019
24answers
Phone freeze unlock code
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000# If your phone says wrong password, turn your phone off and put in an unaccepted Sim Card into the phone (A sim card from another Service Provider) and then start the process over again. If it says wrong password even with the wrong Sim card, then you have reached your second attempt, Do NOT try it again. Instead, go to Ebay and purchase an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now that you know your phone's unlock code, (00000000) you can use the following codes to unlock individual locks on your phone (Where you see the word Code you will put in your new unlock code, which is now 00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
3/31/2019 4:10:22 AM • Samsung SYNC... • Answered on Mar 31, 2019
My samsung a766 in in phone lock
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
12/4/2018 3:16:37 AM • Samsung SYNC... • Answered on Dec 04, 2018
How do I unfreeze my
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
11/15/2018 1:12:20 AM • Samsung SYNC... • Answered on Nov 15, 2018
How do I transfer text messages from my Samsung
Now, you can transfer text messages from Samsung phone to computer by using pro Android data recovery software. With its help, you can easily access text messages on Samsung phone and transfer them to pc. How to Transfer Text Messages Conversation from Samsung Galaxy Note to PC
11/2/2018 6:10:40 AM • Samsung SYNC... • Answered on Nov 02, 2018
I need help to take
You need to Unfreeze the Phone,You can get the Unfreeze Code from here Prounlocking.com and Unfreeze the Phone from Freeze ....
Login ' Register ' Currency Pro Unlocking.com Experts in Mobile Phone Unlocking rrmus-8.gif Samsung T669 Gravity T samsung-sgh-t669.gif Country Network Samsung T669 Gravity T Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung T669 Gravity T mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung T669 Gravity T mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung T669 Gravity T with a NOT ACCEPTED SIM Card.
2 - Samsung T669 Gravity T will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung T669 Gravity T shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung T669 Gravity T.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung T669 Gravity T is locked to.
CODE: Its the unique Unlock Code for your Samsung T669 Gravity T.
9/28/2018 1:22:03 AM • Samsung SYNC... • Answered on Sep 28, 2018
0answers
I have a samsung sync phone and the screen cracked. Now i cant see anything on the screen.
Displays from one phone brand to another are not usually able to be used in another brand, kind of like trying to put a Ford engine in a Chevy.
You should try to connect the phone using a USB cable (the charging cable) between a PC and the phone. That usually auto-mounts the phone as an external drive of the PC.
Then you can browse to the folders on the phone where the photos are and copy them to the PC to preserve them.
If you don't have a PC, perhaps a friend has one, a laptop or desktop, Mac or Windows, shouldn't matter which, and they would help you copy the photos.
If I were doing that for a friend I would then burn them to a CD or DVD as data to save them, or make a video slide show of them to play in a DVD player, or both.
Sorry for the loss of your sister. Hope these ideas help.
The only other options are a screen repair by a qualified tech or a phone uograde. Most carriers will copy your data to a new phone during that process, and you would want to explain how important the photos are to you and verify they survived the transfer ok.
2/24/2018 2:15:29 PM • Samsung SYNC... • Answered on Feb 24, 2018
2answers
Samsung sync hardlock
your sim chip totally damage. change sim or" number.
2/1/2018 1:57:48 PM • Samsung SYNC... • Answered on Feb 01, 2018
2answers
Sd memory card
You can buy them anyplace that sells electronics. Best Buy, Circuit City, WalMart - as far as cost, it depends on what size you get.
The phone has a limited memory, which is used by phone numbers, pictures stored in the phone, and the phone's base software, so music would eat the phone memory up pretty quick.
When you buy the micro SD card, it usually comes with an adapter for PC media readers.
I just checked ebay and I saw 2GB for 11.00 shipped. That is a great buy!
11/10/2017 1:43:52 PM • Samsung SYNC... • Answered on Nov 10, 2017
Samsung SYNC SGH-A707 Cellular Phone Logo
1,016 questions posted
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SGH Samsung
  • SGH Samsung
Most Popular Question
  • Cell Phones
