Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the
freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the
freezer...you should see ice build up on the evaporator...don't worry get a
hair dryer and melt the ice. Next locate the wires for the
heater...using a multi meter test the
heater for condinuity...if the
heater is bad replace it, If the
heater is good replace the defrost
thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with
pictures of what the parts you need to check are:
http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat
http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free
solution.
