20 Most Recent
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Questions & Answers
Right side door pops open when left door is closed
Is this a new unit? This is caused by air rushing into the other compartment through a damper control. Most mfr's. install an air check valve at the bottom of both doors that will pop up to let external in, thus alleviating door blow out.
Apply a food grade silicone to the face of the door seals to add tackiness to to the surface. Follow link to purchase.
https://www.repairclinic.com/PartDetail/Silicone-Lubricant/WP99003172/1074750. A suitable substitute would be a little Vaseline. I’m happy to assist further over the phone at
https://www.6ya.com/expert/david_dc2f9e0a44104720
Water dispenser not working
The solenoid that lets the water floe isn't working. It could be the switch on the dispenser or the solenoid itself
Water filter
take the old one off and go to home depot, or sears, they have it for sure
Water dispenser sudden low flow/pressure.
Sounds to me you have something wrong with the filter and retaining air there. That air must be purged to get the pressure you need from water supply. Double check that water filter I think your problem is there, Thanks
Sea Breeze
