Canon PowerShot ELPH 340 HS Black Digital Camera 16 MP, 12x Opt, SD/SDHC/SDXC Card Slot Logo
R
Rhea Sax Posted on Oct 31, 2015
How to turn flash off on canon elph 340 hs? - Canon PowerShot ELPH 340 HS Black Digital Camera 16 MP, 12x Opt, SD/SDHC/SDXC Card Slot
3 Related Answers
seofelite
Jonathan
  • 114 Answers
  • Posted on May 01, 2011
SOURCE: How do you playback video
User Manual
Page 31.
Anonymous
  • Posted on Jun 06, 2011
SOURCE: How do I use the
Once you select the color accent you should see the word " menu" in the bottom left hand corner of the screen with a down arrow next to a picture of a tube of paint. This means hold down the menu button for longer than a second, then you can adjust the color to be accented in your photos. Any time you see the word menu and the down arrow on the screen it means hold the menu button for longer than a second for more options/setting adjustments.
  • 102366 Answers
  • Posted on Jul 26, 2011
SOURCE: Need a manual for Cannon
You can download the manual at
http://gdlp01.c-wss.com/gds/6/0300004756/01/PSELPH300HS_IXUS220HS_CUG_EN_02.pdf
Where is the self timer located for the CANON Powershot ELPH 340 HS?
Have a look at page 32 on this manual
https://www.manualowl.com/m/Canon/PowerShot-ELPH-340-HS/Manual/407032?page=32
1helpful
How do i unlock the wifi password on my canon elph 340 hs
To determine the access point password, check on the access point itself or refer to the user
My flash stopped working i have CANON 340 hs powershot n when i took without flash its giving me results
Try to reset the camera settings, then press the flash button (lightning symbol) and make sure it's set to ON mode.
if it still does not work you might need to replace it
Where do I find the authentication code ?
I seem to think that this is located on the box it came in around the area on the bar code.
What is the authentication code for my Powershot canon Elph 340HS?
Once you connect your camera to the Canon Image Gateway site via wifi, you will see an authentication code on the camera. See Pages 87 & 88 in the manual here: https://www.manualowl.com/m/Canon/PowerShot-ELPH-340-HS/Manual/407032?page=87
Hope this helps you!
Canon powershot elph 340 hs
You either need a larger SD card or to reduce the quality of the video you're shooting.
Canon powershot elph 100 hs memory card locked
Look for a small, sliding switch on the side of the SD card. If it isn't on "write protect" the switch or card may be physically damaged and needs to be replaced. Have you tried it with a different SD card?
1helpful
Canon elph won't turn on
check the battery then batt. connectors
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
