SOURCE: On/off works but dimmers do not. leviton toggle
If each pendant has an individual transformer that is about the size of a hotwheel then you need a dimmer specifically for ELECTRONIC LOW VOLTAGE. A lot of electricians don't know that the different types of lights require different dimmers. Most store bought dimmers are for incandescent lights only, and some nicer dimmers like the Lutron Maestro's are rated for incandescent or MAGNETIC Low Voltage which require a different Sin wave interuption. I don't know that leviton makes a dimmer in that style for Electronic Low Voltage. You could install a Lutron DVELV300P-Wh, but that is a Decora opening. http://www.lutron.com/CMS400/WorkArea/downloadasset.aspx?id=25437
Here is a link to explain the difference in how the dimmer needs to work. Good luck!
Testimonial: "Excellent answer! As Lutron is not available in my small town (on an island in Southeast Alaska) I will likely be ordering a dimmer online. Thanks!"
