Just replaced all outer handles and 2 interior handles and a door latch on a sport track. The biggest problem with the locks were that they needed to be lubed. Take a spray like wd-40 and spray the latches. If the door panels are still off then it is easier. Also spray the window sliders to have them work easier. All the actuators work off the same signal. The one that does not work just may need a little lube.
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Inside the truck behind the trim is a manual release for the gas door, the release looks like the head of a large key on a small wire string. It is marked.
It seems that something is clogged in the drain pump
assembly and you have to clean it to solve this issue. After cleaning if the
issue returns then test the door lock assembly, if bad it should be replaced. Hope
this helps...please post back for further assistance.
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
