Home Logo
Peggy Wilson Posted on Jul 11, 2015
DC25959. How do I install the tub?
How do you install?
Washer tub is loose i can move the tub and nothing else moves it appears to be off track any ideas?
My LG washers tub became loose and when I took it apart the spider arm on the tub was corroded and broken this holds the tub straight and it is mounted on spring for vibration. The tub was damaged but repairable and I installed a new tub seal
Istalling a tub
You may not need to install a vent, it depends upon how far the tub is from the main drain. I suggest you check with a licensed plumber.
Apr 17, 2013 • Plumbing
1helpful
NEED THE MANUAL FOR JACUZZI DC25959
You can get the manual on the link below.
http://www.plumbersurplus.com/pdf/15663.pdf
Good Luck
Dec 05, 2010 • Home
2helpful
Connecting a mansfield whirlpool tub pump don't know the model number pump is in the floor and tough to get to. there are 2 cords hanging out. 1 male end and 1 female end. When I plug in the male end, the...
Hello Joe, Typically when you have a whirlpool type tub, there is either a built-in air switch on the tub that will turn the tub motor, on and off, or the tub needs to have a wall switch to turn it on and off.
The switch has to be located so it is at least a minimum distance of 3-4 feet from the edge of either a tub or shower stall, and it must be connected to a GFCI protected circuit. Normally any whirlpool tub requires a separate dedicated 20 Amp 120 Volt AC circuit for proper operation and to meet code.
I believe that the female plug is for an optional, in-line heater that can be installed into the tub unit. You should be able to check the installation manual that came with the tub to verify the proper wiring required for your specific unit and model.
I would contact the manufacturer to get a copy of the installation guide and instructions for your model, so you are certain that it is properly installed and the wiring you are using meet the NEC (National Electric Code).
Here is a link to the Mansfield web site with some FAQ's and their phone contact information.
http://mansfieldplumbing.com/v3/support02-03.html
I hope you find this Very Helpful and best regards!
Eljer garden garden tub drain
Tub overflows are not required in all states but I highly recommend drilling the hole and installing the proper waste and overflow drain I recommend the Gerber brand and also when you set the tub you need to set it in a light concrete for stability I use great stuff foam for setting tubs 2 cans spray on floor and set and level tub tub will never wobble or move
Nov 08, 2009 • Plumbing
4helpful
Where is the windshield wiper motor on a 2007 Dodge Caravan and how do I replace it?
Wiper Motor: Service and Repair
Removal
REMOVAL
The front wiper motor comes as a unit with a wiper pivot on each end and mounts to a shaft that holds these two inner pivots.
1. Disconnect and isolate the battery negative cable.
2. Remove the wiper arms.
3. Disconnect the washer hose at the in-line connector located near the air cleaner housing.
4. Lift the cowl grille and disconnect the washer hose grommet from the hole in the wiper module. Pull the washer hose and the grommet
completely through the wiper module tub hole.
5. Remove the cowl grille.
CAUTION: Be careful not to scratch the cowl grille on the corner of the hood.
6. Remove the four brace nuts holding the wiper tub to the lower windshield fence.
7. Remove the four bolts underneath the wiper tub inner brace holding the tub to the bulkhead.
8. Remove all four inner support brace mounting nuts and pull the inner braces just free of the mounting studs.
NOTE: The wiper tub will drop down slightly.
9. Disconnect the driver and passenger side wiper link ends at the inner pivots.
10. Remove the two left wiper motor assembly mounting nuts.
11. Remove the two right wiper motor assembly mounting nuts.
12. Partially lift out the wiper motor assembly out of the wiper tub.
13. Disconnect the wiper motor electrical connector.
14. Remove the wiper motor assembly the rest of the way from the wiper tub and remove from vehicle.
Installation
INSTALLATION
1. Install front wiper motor assembly onto wiper tub.
2. Connect the electrical connector to the front wiper motor assembly.
3. Install the four mounting nuts. Tighten nuts to 9 Nm (80 in.lbs.).
4. Push the four inner support braces onto the studs and install the four nuts. Tighten the nuts to 9 Nm (80 in.lbs.).
5. Install the four bolts underneath the wiper tub inner braces that hold the wiper tub to the bulkhead. Tighten the bolts to 17 Nm (150 in.lbs.).
6. Install the four nuts holding the wiper tub to the lower windshield fence line. Tighten nuts to 7 Nm (65 in.lbs.).
7. Apply grease to drive link bushings.
NOTE: Make sure to use Mopar(R) approved grease.
8. Attach the driver and passenger side outer wiper linkage to the inner pivots on the front motor assembly and firmly snap into place.
CAUTION: Do not apply too much force to engage link bushing or damage can occur to the drive link bushing.
9. Position the cowl grille in place.
10. Install the washer hose and grommet into the wiper tub.
NOTE: Be sure to properly seat the washer hose grommet into the bottom of the wiper tub.
11. Connect the washer hose at the in-line connector located by the air cleaner housing.
12. Install the cowl grille.
13. Connect the battery negative cable.
14. Verify that the wiper motor is in the Park position by cycling the wipers system. When done, remove keys from ignition.
15. Install the wiper arms.
16. Align the wiper arms and tighten nuts to 35 Nm (25 ft.lbs.).
17. Install the wiper arm nut caps.
3helpful
Install of AS 2425 whirlpool tub
hey bill no easy way what we do is measure height of edge that will sit on stud and tack stud in tub area and dry fit tub.when you do that you can see how much space is under tub for your mortor you should use light weight cement called structolite its white and not as heavy and yes a piece of tar or resin paper is a good idea
Installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Mar 22, 2009 • Home
2answers
I bought a model 2221 peanut soaker tub installation
fill the tub one third full with water you must be able to access the under side of the tub cut hole in drywall if possible spray two large cans of sprayfoam allow 5 hours for foam to set and drain water. problem fixed.
Mar 08, 2009 • Home
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
