20 Most Recent American Standard Evolution 2425V-LHO.020 White 5 Feet x Questions & Answers
You need to install whatever will function best to get the skirt raised up to match.
Rod
US Parts Center
888-521-6183
American... | Answered on Apr 09, 2013
If your back jets do not turn on then there is a valve you need to adjust on the tub somewhere or they need to be turned on by the face of each jet by turning them counter clockwise.
Rod
US Parts Center
888-521-6183
American... | Answered on Mar 09, 2013
Have you considered your looking for a plumbing part
for a common name brand?
Go to a plumbing supply where the pros go
American... | Answered on Feb 01, 2011
some people use spray foam which you can add later
American... | Answered on Mar 25, 2010
No. but it will be noisier when running
American... | Answered on Jun 15, 2009
hey bill no easy way what we do is measure height of edge that will sit on stud and tack stud in tub area and dry fit tub.when you do that you can see how much space is under tub for your mortor you should use light weight cement called structolite its white and not as heavy and yes a piece of tar or resin paper is a good idea
American... | Answered on Apr 15, 2009
sometimes theres caps on top pop the cap and tighten the screws and sometimes there are nut or wing nuts on the bottom...simple enough for you?
American... | Answered on Sep 06, 2019
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
American... | Answered on Jul 12, 2019
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet.
Then....visit this link:
https://www.americanstandard-us.com/parts-support/faqs/toilets
Good Luck!
American... | Answered on May 06, 2019
More likely the sensor has malfunctioned.
American... | Answered on Nov 24, 2018
these are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
American... | Answered on Nov 12, 2018
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
American... | Answered on Nov 04, 2018
American Standard Evolution 2425V-LHO.020 White 5 Feet x Logo
8 questions posted
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
back jets dont work
  • Home
