Computers & Internet Logo
G
Gunter Luckwaldt Posted on Apr 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On a HP 697737-DBI Computer keyboard, How do I use the alternate blue fonts? It has no fn key!
ka4iup
Level 3:
  • HP Master 4,062 Answers
  • Posted on Apr 29, 2015
ka4iup
HP Master
Level 3:
Answers
4062
Questions
0
Helped
1096850
Points
51404
Http://h10032.www1.hp.com/ctg/Manual/c01075722.pdf
Why I can not turn off the alternate blue keyboaod on hp desktop
Solution 1 - Permanent OFF (windows 7)
  1. Go to Start menu > Devices and Printers
  2. Right click on HP Wireless Keyboard and Mouse Kit (yours may have slightly different name)
  3. Left click on Region and Language
  4. Left click on Change Keyboards button
  5. Under General tab go to > Default Input Language section > select English (Canada)-US
  6. Under General tab, now go to > Installed Services section > Keyboard heading > click on item for Canadian French then click the Remove button on the right,
  7. Repeat step 6 to remove line item Canadian Multilingual Standard
  8. Click Apply button at the bottom of window, then click OK button to get out of the window, click OK to get out of final window
  9. Close your Devices and Printers window and you are done FOREVER with the unwanted characters!
Other alternative solution on this HP webpage.
How do turn off the alternate BLUE keys on my HP keyboard
How to activate/deactivate the alternate keys(blue font) on keyboard
Sharing my experience that my windows works properly from site www.vanskeys.com use a key to share you. Hope can help you.
Shift fn keyboard issue
Its shifting to numeric for one key only.
Try changing the batteries, if that does not work, bin it.
Hp laptop numlock lite on,but ten key is not working
Most times you have to press an hold the FN key at the lower left portion of the keyboard to get them to work. If you'll notice, the numbers on keys jkluio789 are in blue and so is the FN function key.
You state to hold the fn, and hit the power button.....OK, whats the ( fn ) key ?
The Fn key is a key found usually on the keyboards of portable computers (laptops, netbooks etc) and sometimes on desktop type keyboards.
It is a key usually marked with a blue coloured "Fn" and is located somewhere on the bottom left row of keys.
The Fn key is used in combination with other keys that have (usually) blue letters or icons on them to activate the special functions (Fn) on these keys.
For example, on the laptop I'm writing this on; If I press F5 the computer would perform the action my software has normally assigned to F5. If however I press the Fn button and F5, the computers internal function for decreasing screen brightness is invoked.
Different computer makes have different assignment to their keyboard Fn so you can't generally say press Fn+F5 to decrease screen brightness, it might be assigned to something else, volume or sleep-mode or even nothing. The "blue" text or icon will give an indication of what it will do.
Hope this helps explain the Fn key ;)
3helpful
2answers
How to use keys
There is a BLUE-coloured 'FN' key on the bottom-left of the keyboard. Hold that key down, and then press one of the "blue" keys, to get the "alternate" meaning of that key.
15helpful
How to turn off blue keys for an Compaq mini cq10??
if you are refering to the blue letters or alphabets which are present on the keyboard. HP designs keyboard with a billingual layout in some Notebook models.
The HP "Blue" keys are indeed the "French" input keys or other language keys.
How to use the Blue Symbols or keys on a HP Notebook:
We can activate them by pressing Ctrl+fn+right Shift.To deactivate, press Ctrl+fn+right Shift twice, i.e. Ctrl+fn+right Shift then let go off Shift while still holding Ctrl and fn, then press Shift again.
When you press Ctrl+Fn+Right Shift it will switch to the the billigual layout. That means the blue characters become prioritie.
For example, if you are in the billingual layout, when you press shift+6 you will get a '?' but not the '^' sign.
I've got two hp laptops with broken monitors, I've
Usually you have a key named Fn on the laptop keyboards.
The common combinations for alternate display are :
Fn+F5
Fn+F4
You can try both the combos. Need to press both the keys together.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
