Allan Aaron Posted on Apr 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine trouble c3451
What does error code c3451 mean?
Heeyoon Shin
Level 2:
New Friend:
  • Expert 28 Answers
  • Posted on Apr 03, 2015
Heeyoon Shin
Expert
Level 2:
New Friend:
Answers
28
Questions
0
Helped
8561
Points
155
1helpful
My Bizhub C252 Konica Minolta is getting error C-3451? How can I fix it ?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
??? ??? ??? c3451
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
1helpful
Konica-Minolta bizhub 215 giving c3451 error message?
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
How can i solve the problem of c3451?
What if the machine is showing c3451, what should we do?
Hi Stephen,
This error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
Try resetting it by switching machine off using the switch inside the front door, not the one on the control panel.
This will hopefully reset the error code. However, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
6helpful
2answers
Error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
hope this helps
2helpful
3answers
Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
2helpful
3answers
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
k24674
ADMIN Andrew
ADMIN Andrew
