The washer makes a loud continuous noise when it goes into its spin. The washer is normal in other cycles. There is a light abnormal vibration that is not normal. The noise is LOUD. My wife tells me grease marks are on white clothes.
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
SOURCE: Final spin making very loud noise vibrates with
Open the door and see if the basket has any up and down "play" in it. what you're doing here is checking the rear bearing assembly. There should be no "play"/movement (other than the entire tub assembly moving on the shocks/springs obviously). the rear bearing in any front load machine has practically zero tolerance. meaning it shouldn't knock when spinning, or have movement in the basket if you try to move it with an up & down motion.
If you DON'T have nay unwanted motion, make sure you are using the right detergent, that the unit is sitting level on all four feet/legs, and that the shock absorbers and springs on the tub aren't broke or seperated from the cabinet.
If you DO have unwanted motion/up & down play, you may want to consider a new washer, unless you have extended warranty or canet a could "used" one for parts.
Also check for any signs in the cabinet for pieces of concrete from the counterweight at the front.
At this point, before removing any parts/panels etc. **Unplug the unit from the wall**
You'll need to remove two screws at the bottom in the front to remove the lower panel for checking the shock's and counterwight, and remove the top to check the springs. There are two or three screws at the top in back to remove the top panel.
hope that helps,
Good Luck :)
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
SOURCE: loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
