Yes, but I would advise to try a washer cleaner before going through all the work to dissassemble your machine.
Use the longest, hottest cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer.
You could check out
http://www.smellywasher.com/ for one possiblity. Others are " Washer Magic " or these:
If you still want to tackel the dissassembly: The washer front comes off by using a putty knife to push in the two retaining clips on the very top edge, where it meets the washer top. Now you will be able to access the screws which hold the top down. Of course to remove the inner tub, you still have to remove the lid switch, the agitator, agitator drive, the left hand threaded nut below that, the wire connection to the motor, the four tub retaining straps, the tub to pump hose, the four suspension rods, the tub cover and the water level hose. Then you would be able to remove the inner tub and pressure wash out the outside of the inner tub and the inside of the outer tub, if you bring the tub assemble outside. TRY THE CLEANER FIRST !!!!
