Here is a sample of the percentage calculations that the calculator can perform. You will not see among them the conversion from decimals to percentages. To convert from decimals to percents move the decimal mark 2 places to the right and append the % sign. To convert from percents to decimals, move the decimal mark 2 places to the left.
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
You can try pressing "alpha" or "2nd" and then pressing the key you saw the percent sign on.
here is a temporary solution in case that doesn't work:to enter a percentage up to write the digits before the tens and ones (if any, and if not, just type a zero), a point, and the last two digits.ex:
56%=0.56
28%=0.28
132%=1.32
4243%=42.43
To write down the answer, take all the digits, take off the point, if the percentage is 99% or less, don't write the zero on the right of the period, and add a percent sign.
Hi. Try this steps on using your math calculator for the percentage function.
Hope This Helps
Step 1. Note that not all calculators behave the same way as far as the percentage key is concerned. Thus, test the examples in this article on your calculator. If your calculator does not have the percent key or does not behave in the way described here, don't despair - you can still use it to calculate percentages, it's just that you will have to press a few more buttons.
Step 2. Let's calculate a tip on your restaurant bill. Suppose your bill happens to be $64.35 and you would like to leave 15% tip.
Type the following into your calculator: 64.35 * 15 % Answer: 9.6525 or $9.65 after rounding.
Most simple calculators will give an answer right here without having to press the = sign. If yours does not, press = and see if you get the right answer.
Alternatively, you can calculate this percentage by typing in 64.35 * 15 / 100 or 64.35 * 0.15
Thus, you may have observed that all that the percent key did here was division by a hundred.
Step 3. Let's calculate a grade percentage - say you got 34 out of a maximum of 40 points.
To figure out your grade percentage type in: 34 / 40 % Answer: 85
Alternatively, without the percent key: 34 / 40 * 100
Step 4. Let's calculate a sale price on those shoes that originally cost $139, but are now discounted by 35%.
On your calculator type in: 139 - 35 % = Answer: 90.35 or $90.35
This calculation is amazingly easy with the percent key! Alternatively, you would first have to calculate what the 35% of the $139 is and then subtract it from 139: 139 * 35 / 100 = 48.65 139 - 48.65 = 90.35
The issue is the fact that you are adding the %. You need to Multiply it by 1.1 instead of trying to add 10%. This is a wonky equation anyway, because your not specifying what you want to add 10% of. This is why you are getting a weird answer.
I have a Casino MS-80S and yea, the percentage works different. As example to take 100 and subtract 10%, this is what I do: 100 X 10% - and then I get the answer 90 after I press the minus key. To add the percentage instead, 100 X 10% + will give me an answer of 110, after I press the plus key.
Equals is used during a calculation of division, percentage, multiplication, etc. Use the total key or * key for a total of substraction or addition.
If this helps, please rate me. Thanks, Patty
I've been searching for the solution to this problem, as well. Apperently, there's no user's manual for this calculator. I'm going to call Casio on Monday to see if they can send me some sort of instructions. (800)962-2746 or (609)395-0154
