20 Most Recent HP 35s Scientific Calculator Questions & Answers
What is the percentage of 2458.07 from 3304.72
2458.07 is about 74.4% of 3304.72
9/15/2014 7:16:02 PM • HP 35s... • Answered on Sep 15, 2014
Where is the percentage button?
You can try pressing "alpha" or "2nd" and then pressing the key you saw the percent sign on.here is a temporary solution in case that doesn't work:to enter a percentage up to write the digits before the tens and ones (if any, and if not, just type a zero), a point, and the last two digits.ex:
  • 56%=0.56
  • 28%=0.28
  • 132%=1.32
  • 4243%=42.43
To write down the answer, take all the digits, take off the point, if the percentage is 99% or less, don't write the zero on the right of the period, and add a percent sign.
6/4/2014 12:55:45 PM • HP 35s... • Answered on Jun 04, 2014
How to but the calculator in enginering mode
Press left-shift DISPLAY 3 then a digit for the number of desired digits.
6/2/2014 6:57:08 AM • HP 35s... • Answered on Jun 02, 2014
Changing base 8 to base 10 on a HP35S
Press right-shift [BASE] 1
6/2/2014 6:55:25 AM • HP 35s... • Answered on Jun 02, 2014
How to change sign on hp35s
Press the +/- key.
6/2/2014 6:15:33 AM • HP 35s... • Answered on Jun 02, 2014
How to remove BIN from, HP 35 Scientific Calculator
Press right-shift [BASE] 1 to switch to the decimal mode.
6/2/2014 6:11:32 AM • HP 35s... • Answered on Jun 02, 2014
Need to change display from a comma to a decimal
Press left-shift DISPLAY 5
6/2/2014 3:09:00 AM • HP 35s... • Answered on Jun 02, 2014
How remove fraction
Press right-shift [FDISP]
6/1/2014 3:24:18 AM • HP 35s... • Answered on Jun 01, 2014
How to remove RAD from HP35s
Press MODE then 1, 2, or 3 to select the desired angular mode. In any mode other than degrees the display will indicate the mode.
5/31/2014 10:46:42 PM • HP 35s... • Answered on May 31, 2014
How to change comma to decimal
5/31/2014 10:42:07 PM • HP 35s... • Answered on May 31, 2014
HP 35S SETTING NUMBER OF DECIMAL
Press left-shift cursor-left 1, then enter the desired number of digits.
4/15/2014 11:57:26 PM • HP 35s... • Answered on Apr 15, 2014
HP 35S WHERE IS THE FIX BUTTON
There isn't one. Press left-shift cursor-left 1, then enter the desired number of digits.
4/15/2014 11:57:19 PM • HP 35s... • Answered on Apr 15, 2014
0answers
HP 35s in OCT mode, calculations don't work
There are two separate issues here. Your calculator is in Algebraic mode. To switch to RPN, press MODE 5 . Your calculator is also in Octal mode. To switch to Decimal, press right-shift 1 1 .
3/24/2014 3:33:07 PM • HP 35s... • Answered on Mar 24, 2014
0answers
Won't turn on
Be the first to answer 3/2/2014 3:02:34 AM • HP 35s... • Posted on Mar 02, 2014Be the first to answer
0answers
Clear a HP35s
Be the first to answer 2/11/2014 10:00:01 PM • HP 35s... • Posted on Feb 11, 2014Be the first to answer
HP 35s Scientific Calculator Logo
56 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
hp 35s in oct mode calculations dont
  • Office Equipment & Supplies
