20 Most Recent Texas Instruments TI-84 Plus Calculator Questions & Answers
Is it somehow preventing you from graphing, or are you simply not getting the graph you expect?
Most likely you have the angular mode set wrong. You probably want it set to radians. Press MODE, move to the third line, highlight RADIAN, press ENTER, then 2ND [QUIT].
If it's not the angular mode, please reply to this post and give an example or two.
Texas... | Answered on Feb 28, 2019
Turn the satistical plots OFF
Press [2nd][Y=] (STATPLOT). Select or enter 4: to execute the command [PlotsOff] [ENTER]
Clear the lists (statistical lists)
Press [2nd][0] (Catalog]. Press [PGRM] C. The cursor jumps to the first command in catalog that starts with C (The greek letters in names do not matter). Scroll down a bit to reach the command [ClrAllLists]. Select it and press [ENTER].
Try your graphs again.
If you still have problems, just reset the RAM:
Press [2nd][+] (MEM). Press 7 to select [Reset] then [1:All Ram][2:Reset]. Press [Clear] to erase the Ram Cleard message.
Now you should be able to draw the graphs.
Hope it helps.
Thanks for using FixYa.
Texas... | Answered on Jan 30, 2019
When you change the batteries the display reverts to default setting. My optimistic guess is that the screen display is so light that you cannot see anything on it. This can be arranged.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. Whileholding [CLEAR], reinsert the AAA battery and then
  4. turn the calculatoron.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cables ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. Whileholding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
If all else fails you can contact Texas Instruments at ti-cares@ti.com
Hope it helps.
Thank you for using FixYa.
Texas... | Answered on Jan 08, 2019
I had that same problem.
the blinking black box on my calculator would stay on.
every time I turned on my calculator, it would say 'ram cleared'
if I held down a button for 2 seconds or so, it would finally respond
SOLUTION:
blow really hard into the I/O port. It fixed it for me!
Your calculator is set to radians, which is the norm for higher mathematics. To set it to degrees, press MODE to bring up the mode editor, press down-arrow twice to get the the angular mode, press right-arrow to highlight "DEGREE," and press ENTER. Press 2ND [QUIT] to exit the mode editor.
Texas... | Answered on Oct 04, 2018
Use the division key.
Texas... | Answered on Sep 07, 2018
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install.
Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Texas... | Answered on Aug 20, 2018
on a calc that's work properly, in the 'y=' screen, none of the 'Plot#' things are highlighted. try pressing 'y=', and if you have a 'Plot#" in a black box, go up to it and press enter to un-highlight it.
either it will work as soon as you press 'graph',or you have another problem
Texas... | Answered on Jul 13, 2018
Press Mode, and change display mode to float.
Texas... | Answered on May 21, 2018
It is 1
Texas... | Answered on May 20, 2018
The key allows you to enter different variables, X for function graphs, T for parametric graphs, Theta for polar graphs and n fro sequence graphs.
Cosine values are between -1 and 1. The arcosine domain is between -1 and 1. The value you have is out of range.
Square root of (y^5)
Question?
Read about the nature of the cursor. It can be on Insert or overwrite. If the cursor is full square and flashing, that mean the memory register for the input line is full and you cannot input anymore strokes.
You may be making a confusion between intercepts and intersections. Intercepts are crossing of the axes. Intersections are between two curves: You need to have two curves graphed. You choose the first curve by selecting it (Up or Down Key), and then the second one.
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Texas... | Answered on May 03, 2018
Press
9 3 . 6 / ( 1 . 5 + 6 * . 4 ) ENTER
on your TI-84 Plus to see the answer.
Texas... | Answered on Apr 17, 2018
Texas Instruments TI-84 Plus Calculator Logo
2,174 questions posted
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Texas Instruments Office Equipment & Supplies
Most Popular Question
when try turn shows waiting please
  • Office Equipment & Supplies
