$14.88
$18.73
Free shipping on orders over $35
Arrives by Thursday, Nov 15
Options
Free pickup today
In stock at San Leandro, 1919 Davis St
Options
Add a
Walmart Protection Plan
powered by Allstate
The thread pulls out when you begin to stitch? Pull more thread tail through the needle eye. You can also try holding the thread tails in your left hand when beginning the first stitches.
First make sure you are putting in needle correctly, it has a flat side. Insert a new needle into your sewing machine with the flat side away from you. Push the needle into the clamp until it touches the pin (a) and stops. Firmly tighten needle clamp screw with the screw driver.
if you find all the thread bunched up then look at your thread not being routed through all the the locations. Go slow and retread from beginning.
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem,, the feeddogs may need to be checked to see why they are not moving the fabric thru the machine.
Skipped stitches
For a timing problem.
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust 5. are the needles the correct ones for the serger 6. Possible timing problem--need to be checked at a sewing machine shop
Serger may have a threading diagram inside the front looper cover which should show the various thread eyelets that you need to pull the threads through and they may be numbered one to 4 also to indicate order of threading. The diagram is usually colour coded to match the tension dial colours and serger usually has colour dots on the different thread eyes to help you follow the thread path for each thread.
This video is great and hopefully will help you http://www.youtube.com/watch?v=zszJYQe2aws&feature=related, it has lay in tensions while yours has dials so just pull the thread around the dial right to left and then across to the next thread eye and this should pull the thread into tension. Dials are usually all set to 5 for normal stitch formation.
On my serger you thread up in the following order: top looper (second from right dial), bottom looper (right hand dial), then right needle, left needle; this video shows all threading going from right to left however, so if you have a numbered diagram inside your thread cover, then certainly use that order. But always loopers before needles.
Raise the thread aerial first before you start, put the cones onto the thread spools and if you have any cone holders (little plastic triangles) put them on the spools first to steady the cones. Now for each thread, take the thread tail from the cone, up through the aerial thread guide, then follow the coloured dots and take this down the front of the serger putting it into each coloured thread guide, through looper then up under the raised pressure foot. Repeat for next looper, then the needles.
Pull all 4 threads out under the foot to the left, lower foot, then chain off a little to start and test sew on fabric, adjusting the tensions if you need to.
Other adjustments are stitch length (usually a knob on right beside the flywheel numbered 1-4, blade position, a dial either left or right of the blade, press on the blade to release the tension on it before you try and move it. And differential feed, this is also a knob numbered 0.5 to 2 usually. If you can't see this on the right by flywheel then open up fabric plate (left cover) and look in there for these two adjustments.
I would suggest you start with tensions on 5, and stitch length of 2-3, and test sew on scraps of the fabric you wish to overlock. You can then either move the blade to cut wider or narrower to suit and adjust the two looper tensions if you need to close up the thread on the cut edge. There is no black and white settings as each fabric will behave a little differently, generally you adjust the looper tensions a bit until the stitch is encasing the cut edge and you have a seam width that suits the weight of the fabric.
Differential feed leave on zero unless you find you need it when a loose weave fabric goes wavy, then turn it down to close up the feeding. Sergers have two feed dogs, one before and after the foot and turning differential knob changes the ratio of feed between the two so either stretches the fabric, or pushes it together as it goes through the stitching sequence. So by turning differential feed up to 1.5 or 2 you are stretching the fabric and you can do a narrow rolled hem edge that is all fluted (lettuce edging).
I hope this helps you out a bit, if you are completely new to this machine and have never used a serger then I always suggest taking a class from a local dealer, it is really worth the money and time as they are quite different to sewing machines but once mastered, really change the dynamics of sewing and techniques are much more like commerical production with flat construction etc.
Set you differential at 1.0 and your loopers at about 3-4 the needle thread tensions are usually around 5 to 6. I would also suggest that you place four different color threads on machine to make it easier to adjust all. Now if you are using only 3 threads the same applies. Also------patience.
