Ensure your router is located in an area which has good line of sight to the devices likely to use it. Steel, concrete and other electronic devices affect signal strength.
Can you give more information about where the device is located and the typical range you are experiencing. You may also wish to look at your routers radio settings mode (5 GHz / 2.4 GHz) and verify compatibility with WiFi devices on your network - match channel modes with radio settings.
Failing all of this you may wish to consider expanding your WiFi coverage with a WAP (wireless access point)
Place it in the middle of the room. All walls, special concrete, will degrade the signal. But what also makes WiFi degrade is other modems close by. Even if they use another "channel" The best results can be achieved with 2 band modems. 2,4 GHz and 5 GHz. The 5 GZH is not yet used that much and although the reach is less, the chance other users will degrade your signal is smaller.
