20 Most Recent Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Questions & Answers
I have installed the moto
sbg6580 or what? you failed to use real model. first off wired Ethernet is always faster.WAN (and the web actual) say wifi not wireless there are many wireless and wifi is but 1. there are 2 speeds, raw and real (throughput) latter is real. and is bits per second not BYTES. The 802.11a and 802.11g networks usually run no faster than 20 Mbps.. the answer is simple one or both wifi devices is slow either or both. the speed will based on the slowest one, called band width bottle-necking.. just like driving a car really , traffic and narrow roads are slower. or are gravel roads, see? so buy new wifi upgrades wifi 5 or 6, , 802.11AC or AX yours is old and slow and more money always buys faster cars or better roads or wifi. speed costs and is not free. read here first but gee upgrades are the answer. but no hardware told yet now just the modem/router your SB Wi-Fi N300 2.4Ghz + N300 5GHz Dual Band Router. The IEEE 802.11 Standard on Wireless LANs (Revision B, Revision G, and Revision N so if he PC is not N or is not dual bad it can not do N speeds or is B or G speed now) 100 Mbps is max speed on "N" 11N and must be close to the router and both bands enabled on both ends and no huge traffic on those bands in your home or IOT there or in the hood (crowded apartments omg bad) your router is not junk, but most old PCs are unless upgraded. and lots of IOT things are 1 band and slow. no brink or concrete walls from PC to router. wifi is radio and does not link dense obstruction LINE OF SIGHT.
6/2/2022 2:29:27 PM • Arris SURFboard... • Answered on Jun 02, 2022
I have a Motorola SURFboard
last man running XP the virus magnet , oops???? no future there. no PC told no wifi card model told. and what 2wire means I guess 2 antenna wires sure. SBG6580 this is cable mode + router both in one, AIO +wifi 'N" grade step 1; the PC works great i wired mode ethernet to rear of surfboard no, then the modem is failing call the ISP. yes, wired works so now comes pesky love/hate wifi next. 1billion posts on the web, pain. ... I can fix them all but is hard work. rule one in this regard, NO PC told but WPA (1) must be enaBled the router side. of surfboard. I have all mine set to wpa2/3. (wep and wpa1 blocked) as did yours new, wpa1 is off. but you do as you want if old things in the home that only do wpa1. then what you set. the SSID and PW are both , case sensitive. worse yet some characters are not allowed either end. page 24 in your manual states, RTM amazing what is there, behold. WPA2-PSK is automatically set as the default page 47 shows, and do pick it there inside the router this Select one of the following wireless network security options for your wireless network from the Wireless Security drop-down list: WPA: Wi-Fi Protected Access WPA-PSK: Wi-Fi Protected Access with Pre-Shared Key, standard encryption WPA2: Wi-Fi Protected Access version 2 with Pre-Shared Key, standard encryption with the AES encryption type WPA2-PSK: Wi-Fi Protected Access version 2 with Pre-Shared Key (recommended) 8.Choose the wireless network encryption type in the Encryption field: AES- Advanced Encryption Standard: Provides the strongest encryption (recommended) AES+TKIP- Advanced Encryption Standard and Temporal Key Integrity Protocol: Allows both AES and TKIP-capable clients to connect to your wireless network. just so you know, newer routers are like this,.today... and are way more secure too and less bugs. ! old bad, new good. ad_hoc or guess mode are gone forever WPS+ pin gone ,too, (now, new Netgear is preset ssd +pass ,NIB label on router shows this.fact. and WPS button GONE. WEP gone for ever, it is insecure max. wpa (fear growing) but may have it or just alone.aka wpa1. or show up as wpa1/2 then see WPA2/3, like mine, and wpa1 is single choice. what your PC and TV;s need and demand I can not guess. is using a PC learn what WPA it uses.(age of PC is the key) learn what other things in home use or need (IOT) yes some old things are wpa 1 only. no higher. then make your choices for sure all same and wpa2 if can. and then set the router to that. and use a PW that is only alpha- numeric and does not use dictionary words. or all upper or lower, mixed can be hard to learn here is me using lastpass, autogen example: only, use a one case SSID. 62D477H6XY the write it down using PAPER>
6/2/2022 1:34:18 PM • Arris SURFboard... • Answered on Jun 02, 2022
Motorola SBG6580
Open Device Manager and set the wireless adapter Power tab to not turn off to save energy. Or modify Sleep mode to not turn off wireless adapters and USB devices. USB if you use a USB wireless adapter.
1/29/2018 11:18:15 PM • Arris SURFboard... • Answered on Jan 29, 2018
Wifi disabled on router
Sounds strange, unplug and plug it back in to see if you get lucky. If your sure there is nothing else preventing the wireless form being activated you might have to reset the router and hope that works. Good luck.
12/22/2017 1:18:19 PM • Arris SURFboard... • Answered on Dec 22, 2017
Firmware upgrade
The ISP is correct in telling you not owner upgradeable. Only because the upgrade is their property. The firmware is coded for their cable lines to distribute the power levels through the cable. If you're having intermittent disconnects, you should call them and ask for a LEVEL3 tech to come to check the cable connections from the "TAP" (which is where the cable comes to home), it's possibly needed to rewire the cable and splitters in your home
10/31/2017 10:56:55 AM • Arris SURFboard... • Answered on Oct 31, 2017
0answers
I have dell desktop and
Hi this is linda and am expert to solve your issues kindly call us to this number +1(518)348-9393, we are glad to help to resolve your isssues.
10/6/2017 8:01:43 PM • Arris SURFboard... • Answered on Oct 06, 2017
The wifi light continuously flickers
Try logging on to the Router and re-configuring/re-setting it.
9/28/2017 4:56:41 AM • Arris SURFboard... • Answered on Sep 28, 2017
Apple products won't connect to network
May experience is that a lot of Apple products have problems with 5 Ghz wireless unless the conditions are near perfect. 5 Ghz has more difficulty penetrating things like walls than the older 2.4 Ghz. If during the setup you decided to disable the 2.4 Ghz, this could be the problem.
4/18/2017 12:38:57 AM • Arris SURFboard... • Answered on Apr 18, 2017
Okay, so I have a Motorola SBG6580 SURFboard
Are you trying to connect a customer owned SBG6580 to a Comcast network?
3/24/2017 5:11:21 PM • Arris SURFboard... • Answered on Mar 24, 2017
2answers
Wireless signal loss with SGB6580 modem. this
If you log into your router by opening a web page and going to "192.168.0.1" log in, under "Firewall" turn OFF "IP Flood Detection" and "Firewall" this will fix that and make it like lightning.
12/27/2016 6:20:17 AM • Arris SURFboard... • Answered on Dec 27, 2016
2answers
My ipad and my iphone wont connect to the
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
9/12/2016 1:53:22 AM • Arris SURFboard... • Answered on Sep 12, 2016
How do you change your wifi password
Follow the steps one by one: 1.Open a browser window.2.Type in the IP address for the modem 192.168.0.1.3.Type in the default Username: admin.4.Type in the default Password: motorola.5.Type in your new username in the Password Change Username field.6.Type in your new password in the New Password field.7.Re-enter your new password.8.Retype your new username in the Current Username Password field.9.Click Apply.10.Write down your new password and default password for future reference.
5/30/2016 12:21:06 AM • Arris SURFboard... • Answered on May 30, 2016
2answers
Which numbers on the sticker on the back of the modem are the password/passphrase and which numbers are the PIN
Even though it's an Arris, try this: 1. Open a browser window.2. Type in the IP address for the modem 192.168.0.1.3. Type in the default Username; admin.4. Type in the default Password; motorola.If that doesn't work, try "root" for the username and "motorola" for the password and reset it to factory settings. Then start again with the steps above and change the username and password to whatever you choose. Good luck!
5/4/2015 12:05:04 PM • Arris SURFboard... • Answered on May 04, 2015
I have a SBG6580. I am trying to enter the security key but cannot find it on the back of the router...please help
I shall have to assume you in a 'Factory Reset' situation, where you have not signed into the modem, and changed username/password defaults, (new unit, fresh out of the box). Do not connect to the cable company yet. First, secure the modem..... From the User Manual, page 9..... You do have a User Manual? 1. Open a browser window, after connecting your computer. Use a 'wired' connection. Never change security settings, using Wi-Fi connection..... 2. Type in the IP address for the modem 192.168.0.1 in the URL address. That should take you to the modem's password change window. 3. Type in the default Username: admin. 4. Type in the default Password: motorola. 5. Type in your new username in the Password Change Username field. 6. Type in your new password in the New Password field. 7. Re-enter your new password 8. Re-type your new username in the Current Username Password field. 9. Click Apply. 10. Connect the modem to the cable company. You should shortly be able to go online, after the modem has synchronized to the cable company. That usually takes about a minute. Your question asks for the 'security key'. That generally refers to the Wi-Fi settings. If that is the case, go to the 192.168.0.1 address, sign-in, and click on Wireless. Follow the obvious directions.... Or, post here again....
2/12/2015 10:29:26 AM • Arris SURFboard... • Answered on Feb 12, 2015
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
389 questions posted
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SURFboard Arris
  • SURFboard Arris
Most Popular Question
motorola surfboard gateway sbg6580
  • Computers & Internet
