20 Most Recent
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Questions & Answers
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ). Try this.If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.If it is windows computer then cisco connect software might be under All Programs.If is a MAC computer then cisco connect might be under Applications.Open cisco connect software.Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.If nothing is working then you will need to reset the router and reconfigure it.Remember once you reset the router, you will need to reconfigure it from the scratch.Click to see more information about cisco connect software
My laptopcant find the router signal
if your laptop detect more wireless signals my be your router have issues if not may you need to try installing a new wireless card $10 on ebay
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
I just recently moved to a new location. We
Most likely this is not a problem with the router, but with the modem or the connection that at&t is providing to you.
I would suggest calling at&t and have them check your connection.
You should check the filters on each of your phones jacks to make sure that they are in place and properly connected. Additionally, you should check the wiring for any damage or poor connections in your phone lines.
Change password
Cisco Linksys E1000 Wireless-N Router Router Default
Cisco Linksys E1000 Wireless-N Router Default IP:
192.168.1.1
Cisco Linksys E1000 Wireless-N Router Default Password:
admin
Cisco Linksys E1000 Wireless-N Router Default Username:
linksys
COMPUTER INSTALL A WIFI
If you are just starting, please follow the instructions in the user guide. It will step you through the process, and you should be up and running in no time. Here is a link to the user guide if needed: http://www.winotek.com/multimedia/items/E1000_V10_UG_USA_NC-WEB,0.PDF
Where do I find my guest password
all depends on the make but genraly if you login to your router usually its admin then password admin again or changeme or what ever password you have been given then go to wifi settings and its usually at the botum of that page have fun
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
