It depends what connections the TV has. If it has HDMI sockets then you should be able to connect the player via one of them. The sound should be connected using an optical lead from the player to the Sony Center.
However you will not be ever be able to play a 3D movie till you have a 3D TV. It will simply not work.
So at the moment you have purchased a an expensive 3D player which can only play back normal Blu-Ray's and DVD.
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Hello catch22
Find Amp-Menu button on remote and try another Amp Selection. Pro Logic & DTS wont give sound in all speakers while in-put signal is analog.
there is no HDMI connection on the receiver
