20 Most Recent Sony DAV-HDX500 System Questions & Answers
I have a DAV DX170 and was able to program Spectrum remote UR5U 878OL I had to use the AUX button and the code is 317 Works great now.
Sony DAV-HDX500... | Answered on Dec 05, 2018
There's always the possibility that when hi-fi or electronic systems are moved, that they will get knocked about it. This might loosen solder joints or crack pc boards. A visual examination of the inside of the unit might reveal one of these.
Sony DAV-HDX500... | Answered on Sep 18, 2016
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Sony DAV-HDX500... | Answered on Jan 10, 2016
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Sony DAV-HDX500... | Answered on Sep 26, 2015
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
Sony DAV-HDX500... | Answered on Jun 27, 2015
Please use Sony support Solution if doesn't resolve I worry main board need replace for order please contact directly expert avsystempart. com
Sony DAV-HDX500... | Answered on Oct 03, 2014
The Protect Push Power display flashes in sony systems when ever there is an issue with the amplifier, as you say there is no improvement even after you unplugged the speaker terminals, that means it is some internal problem.
to confirm the same, suggest to press the function + next + eject buttons together it will show the cause for the error display, either it will be DC detect or SD detect.
If so then suggest you to refer an authorized sony technician as the unit used almost 90 % smd technology and any inexperienced person can tamper it very badly.
If you are a qualified to handle SMD repairs then my hint for repairs would be to check in the final output stage or stage prior to that(CXD-9788 IC) Also check for the 32V supply apears at the connector. the exact part cannot be pinpointed without testing the circuit thoroughly.
Sony DAV-HDX500... | Answered on Dec 09, 2013
Get a Logitech Harmony 880 universal remote. I have it operating my home theatre, TV, iPod and cable just fine - all with one remote.
Sony DAV-HDX500... | Answered on Oct 30, 2013
90% bad main board PCB, replace it.
Sony DAV-HDX500... | Answered on Oct 06, 2013
Sony DAV-HDX500 System Logo
158 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony dav hdx500 system recently move
  • Audio Players & Recorders
