Connecting your laptop to your TV will require a HDMI cable. Attach the cable to the HDMI ports on the latop and TV, then change the source input from your TV to HDMI and your TV will now display your laptop.
Hi Donna. Do you have an HDMI plug on your lap top? If so, then buy one and connect it to your pc and tv. Change the tv's input so it is on HDMI and change the laptops display settings to projector. (If it's windows 7) or another display setting that will display on both your TV and your lap top screens.
The best place to go is your laptop manufacturers website, follow links for support and downloads. Entering the model details of your laptop as you go. You may also need to select the correct driver for your operating system (XP/Vista/7)
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
You will need a vga cable that plugs into the vga socket on the side of the laptop and the tv, the socket is normally blue both on the laptop and tv.
You will have to lower your resolution on your laptop screen to 800 by 600 to veiw your screen on tv, to do this boot up the laptop and right click on the screen to enter the display properties and goto the settings tab at the top of the window, reduce the resolution to the stated value 800 by 600 and change the the colour quality to 16 or 24bit on the other side. Click apply or ok and reboot the laptop. Ensure in the bios you have set the vga to become your output and you are ready to go. hope this helps.
I think you have installed the nokia pc suit on the lap top,
you need to select the option 'add a device'
select bluetooth as the medium and it will as for a passcode, you just need to enter a 2 or more digit number and enter the same on the mobile.... its how pairing of your lap and mobile happens... (its not some code you don't know its just used for authenticating the mobile or laptop using correctly entered passcode which you select)
here is some simple steps for windows XP's--------password but do it carefully
Step 1
Shut
down or restart your computer. While your computer is booting, press
the F8 key repeatedly until the "Boot Menu" appears and you can select
"Safe Mode." Once you select "Safe Mode," press "Enter."
Step 2
Click on the "Start" menu and then click "Run."
Step 3
Type "control userpasswords2" in the dialog box that pops up, and then click "OK."
Step 4
Click on the account you forgot the password for and select the reset option.
Step 5
Input a new password into both the "New Password" and "Confirm Password" areas. Select "OK."
Static text such as a library of music constantly displayed will burn onto the lap-top screen, therefore, rather select your visualisation option showing a constantly moving pattern during playback. This is a much safer option.
