20 Most Recent Apple MacBook Air Questions & Answers
Hi Sylvia, you should be able to go to the App Store on your MacBook Air and search for "FitBit" and re-download. John
Apple MacBook... | Answered on Apr 07, 2019
This means that the sensor of the lid is probably damaged or detecting a magnetic field somewhere.
Somewhere on the left edge, if you hold a magnet, you will see the laptop go to sleep. Make sure there is no magnet close there.
You can disable the laptop from going to sleep if it "sees" the lid closing. Make then only sure that you need to let the laptop sleep by yourself.
Apple MacBook... | Answered on Feb 17, 2019
I would recommend getting an application called clean my mac, it will dig through your mac and trash unneccesary language files and what not, you can also use it to completely uninstall apps. You might have to pay for it though. I believe there's a free trial.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Apple MacBook... | Answered on Feb 11, 2019
there are many reasons about why your Mac works slowly. you should firstly clean it up. here is article which talks about how to speed a Mac you may need: 11 Methods to Speed up Your Mac
Apple MacBook... | Answered on Jan 26, 2019
Asterisk is an open source framework for building communications applications. It is free and open source. If you are looking for more technical detail about Asterisk on mac follow https://www.apple.com/in/support/mac/ and Mac Tech Support .
Apple MacBook... | Answered on Oct 31, 2018
Try:
1. Turn your MacBook Air off by holding down the power button for about 10 seconds.
2. Hold down one of the Shift keys and press the power button for a few seconds. Keep holding the shift key for about 1/2 minute. This will start the machine in "Safe Mode." It will check to make sure there are no errors on your hard drive and do other tasks to hopefully fix your problem.
3. Once you see your Desktop (if you do), click the Apple menu and click "Shutdown".
4. Start the computer normally by holding down the power button for a couple seconds.
If this doesn't work, you may need to reinstall the operating system. On a MacBook Air, that's a bit more complicated. You'll need either the external DVD drive (an optional purchase for the Air) or another computer. Your computer manual explains how to install software on that other computer (may or may not be necessary) so that you can use that computer's DVD drive to put the disc in and reinstall Mac OS X operating system.
Good luck! Please let us know if you have further questions or problems.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apple MacBook... | Answered on Oct 16, 2018
You're confused. You can only use wireless printers if you have a wireless router.
Additionally, do not use WPS, it is inherently insecure. Set the device up by hand.
Apple MacBook... | Answered on Aug 07, 2018
If you are looking to use snapchat online, that is not possible. snapchat only functions via mobile device or emulator.
http://snapchat.com/
Apple MacBook... | Answered on Jun 12, 2018
You don't. The error code is nothing to do with your iMac - that should be obvious as you get it on different computers, therefore chanmging your browser will have absolutely no effect what-so-ever. The code is being delivered by the web-server you are connecting to - probably AOL
Apple MacBook... | Answered on May 10, 2018
Block pop-ups on webpages
  1. Open Safari if it is not already open.
  2. Choose Safari > Preferences, and then click Security.
  3. Turn on "Block pop-up windows."
Blocking pop-up windows stops only those windows that appear when you open or close a page. It does not block pop-up windows that open when you click a link.
If you block pop-up windows, you might miss important information for a webpage. For example, a website that provides services to you might use a pop-up window to request your user name.
Block unnecessary webpage content
  3. In the "Web content" section, select or deselect types of content you want to block or enable. For an explanation of the options, click the Help button (looks like a question mark).
Source: http://support.apple.com/kb/PH11946?viewlocale=en_US&locale=en_US
Hope that helps!
Apple MacBook... | Answered on Mar 30, 2018
Macbook Air has a different memory set up. The memory is soldered on to the logic board when the unit is built. As far as I know there are no direct memory upgrades developed yet for the MacBook Air.
About your only option is to replace the logic board with one with 8 GB
Apple MacBook... | Answered on Jan 26, 2018
This page should help you out, it all depends on the browser you are using:
http://osxdaily.com/2011/05/10/ad-block-for-chrome-firefox-safari/
Hope this helps
Apple MacBook... | Answered on Oct 03, 2017
Check the headphone jack on the side of your laptop. If you can see a red light inside the jack, then the sensor that determines when headphones are plugged in is dirty or jammed. Compressed air and/or removing and inserting a headphone cable repeatedly can sometimes fix it for a while.
Apple MacBook... | Answered on Sep 01, 2017
when your keyboard and touchpad are not working, try to connect an usb mouse and keyboard to the laptop, just to be sure the system is responding.
if the usb devices work, you can be pretty sure there is an hardware problem. if the usb devices don't work too, maybe the system got stuck, and the best thing to do is a system reset
How to Restore MacBook Air to Factory Settings
if the usb devices work, give a try to the apple hardware test to see if it detects anything.
Using Apple Hardware Test
i had a similar problem a few years ago.. if it's an hardware problem you will need to change all the top case
MacBook Air 13 Top Case eBay
Apple MacBook... | Answered on Jul 30, 2017
http://www.wikihow.com/Delete-Genieo -This seems to cover it
Apple MacBook... | Answered on Aug 26, 2016
In order to help your body, nourishment will play a large in order to achievement. Read an exercise and nutritional magazine. Ought to you write down what you're doing, may be more expected to realize your ambitions. You can become skilled at from an individual do the actual world earlier period and you may
Maybe your downfall to losing fat is trying a new "fad diet" only stop because the actual meals choices are bland or limited. There are some reasons people start and quit diets or start and fail at a losing bodyweight. Although the reasons vary there isn't any generally something specific you r and the needs that have prevented through achieving objectives. So evaluate yourself, write down what you believe will work or operate for you.retain info what you have done with no writing it down.
http://greencoffeesupremecleanseidea.com/green-coffee-180-reviews/
Apple MacBook... | Answered on Aug 13, 2016
Add a New Page. To add a new blank page to your document, go to the Document Elements tab of the Ribbon and under Insert Pages click Blank. To insert a page break, which forces all of the subsequent content onto the next page: Click at the beginning of the paragraph that you want to follow the page break.Jun 20, 2016
Google
Apple MacBook... | Answered on Jul 28, 2016
I am assuming you downloaded a file with dmg for the file extension
the youtube video below shows how to extract the application from DMG compressed file format into an application file
https://www.youtube.com/watch?v=EPS4E6uca64
However I came across a few file downloads that had viruses immeded so be careful with bluestacks !
Andy might suit you better see
https://www.youtube.com/watch?v=8-OlFH_dxWs
Apple MacBook... | Answered on Jul 27, 2016
1,081 questions posted
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Air Apple
  • Air Apple
Most Popular Question
fitbit icon disappeared from macbook
  • Computers & Internet
