20 Most Recent
Dell Latitude E6500 Laptop Questions & Answers
How do I unlock the number key on my E6500 latitude keyboard
Hi Tiffany,
Found this after googling .....
Here is how you enable the number lock feature:
1) While booting up press F2 repeatedly
2) After the Dell logo appears, you will be diverted to a Settings menu
3) Expand "POST behavior"
4) Select "Keypad (Embedded)"
5) Press the "By Num Lock" button
6)Press "Apply"
7)Press "Exit"
Will not charge
The power port on the laptop may be bad. Get a known good AC adapter and test with it. If it doesn't work, the power port on the laptop needs to be replaced.
Ush driver/touch senser
Andrew,
At the link below are the Latitude E6500 Drivers Downloads. Click the link below, choose your OS and then the drivers you need to download.
Latitude E6500 Drivers Download Page
http://dell.to/1lDFBKO
Thank You,
Dell-Jesse
Dell Social Media and Communities
Plugged in not charging
Is your new battery capasity higher than the other one you used before? If so, than the charger may not support or have enought wattage for the new battery
My screen is sideways
Right cllick on your desktop and choose personalize. At the bottom of the left panel click display and then click change display settings. Click on the orientation drop down menu and change it to landscape.
Broadcom ush driver missing
You can find it from your computer manufacturer or if your computer running Windows OS, you can follow this steps.1. Open control panel and go to Device Manager.2. You will something like warning sign.3. Right-click on that and click update driver software.
