20 Most Recent Apple MacBook PC Notebook Questions & Answers
Hope this helps. Got it right off my mac! good luck!
If you don’t remember your administrator password, you can reset it using the Mac OS X Install disc.
IMPORTANT: Because a user with the Mac OS X Install disc can gain unrestricted access to your computer, you should keep the disc in a safe place.
To reset the administrator password using the Mac OS X Install disc: step_1.gif Insert the Mac OS X Install disc and restart the computer.
NOTE: If you are using Remote Install Mac OS X, make sure your computer is set up for remote installation, and then go to step 3.
Using Remote Install Mac OS X step_2.gif When you hear the startup tone, press and hold down the C key until you see the spinning gear.
step_3.gif In the Installer, choose Utilities > Reset Password.
step_4.gif Follow the onscreen instructions to change the password.
You should change your keychain password in Keychain Access to match your new account password so your keychain is unloced when you log in.
Apple MacBook PC... | Answered on Feb 11, 2018
i think your mac's CD/DVD writer is damaged that is why it's not working. get to your nearest customer care. Only they can help you out.
https://crumbles.co/showbox-apk-download/
Apple MacBook PC... | Answered on Jan 08, 2018
replace the cd unit to fix the fault
the cost will be a new unit plus 1 hour labour charges so get quotes from different computer shops
Apple MacBook PC... | Answered on Oct 30, 2017
It sounds like a mechanical issue.
It is a standard inboard DVD drive, many are available on fleabay
Apple MacBook PC... | Answered on May 19, 2017
do you usually lean or put any pressure on the area above the slot-load optical drive? If you have anything flat and plastic around 1/4" (about 1/2 the width as a USB plug) stick it in the optical drive until you just feel it going past the door, and rotate 90 degrees so it opens it a little. See attached photos if you aren't sure what I am talking about7804560.jpg
Apple MacBook PC... | Answered on Apr 07, 2017
Take it easy!Here are some avaiable methods for you:
Measures 1: Bypass Windows 7 Password with Fingerprint Logon
As this method, Windows 7 provides native support for fingerprint biometric devices through Windows Biometric Framework (WBF). Of course, the premise is that your laptop or computer has a biometric sensor.
Measures 2: Bypass Windows 7 Password with An Installation Disc
As we known, the System Recovery Options, provided by computer manufacturer, offers Windows installation disc or the recovery options which can help you reset Windows 7 password. Now, create an installation disc by yourself.
Step 1. Enter system repair disc into the search box in the Start menu, and then click Create a system repair disc.
Step 2. Insert a blank CD/DVD into the optical drive and click Create disc.
Step 3: When you lost your password, insert the repair disk and restart your computer. For a moment, the System Recovery Options is displayed, choose Startup Repair and click Next-Next then it will remove the password automatically.
Measures 3: Bypass Windows 7 Password with Reliable Password Recovery Toolkit
There are various Windows password recovery tools. Take two kinds of widespread toolkit for your reference.
Ophcrack(500M)
Ophcrack is one of the most popular free Windows password cracker based on rainbow tables. It can help you reset Windows password less than 14 characters. Once you forgot Windows 7 password, it is a good choice to download the version compatible with Window 7. However, many Windows users failed to recover Windows password as its large ISO file which is more than 496MB.
Download:http://ophcrack.sourceforge.net/download.php
Windows Password Rescuer(34.3M)
Windows Password Rescuer is a highly appreciated Windows password recovery toolkit, especially designed for novice or new beginners. With this tool, you can get instant access to locked computer without the old password and computer skills. Prepare a bootable CD/DVD or USB flash drive and follow these 4 steps with less than 5 minutes.
Step 1: Download Windows Password Rescuer Professional and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset Windows 7 password successfully
10_8_2011_10_25_51_am.jpg Download: http://www.daossoft.com/download.html
Apple MacBook PC... | Answered on Aug 08, 2016
If you do not have a music player app on the computer, you need to load one. If one is present, check to make sure it is working properly.
Apple MacBook PC... | Answered on Mar 04, 2015
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Apple MacBook PC... | Answered on Dec 31, 2014
Might be a simple fix... have you tried holding down the mouse when you startup your computer? That is the "Eject Disc on Startup" function.
If so and it didn't work, let me know.
Apple MacBook PC... | Answered on Dec 16, 2014
if u have problem inlogin password in win xp then when u power up pressF8 key to login in safe mode.
then clik on administrator
then reset your password.
but if u have bios passwqord problem then u have to rset your bios settings.
Apple MacBook PC... | Answered on Aug 11, 2014
You are experiencing RSS (random shutdown syndrome). This seems to often be due to overheating but there are other factors. Read this article http://support.apple.com/kb/HT1237 and see if a firmware update is available for your laptop. This will often cure your very issue.
Apple MacBook PC... | Answered on Aug 01, 2014
OK, I will give you a complete tutorial so that you can understand how to back your account with different ways so read this http://support.apple.com/kb/HT5787 and need more help related to your account follow Apple ID Support .
Apple MacBook PC... | Answered on Jul 23, 2014
you'll have to provide proof of ownership/purchase with apple. It requires a boot disk or knowledge of command line for a third-party individual.
use the eject key, above delete on the right side of the keyboard.
Apple MacBook PC... | Answered on Jul 18, 2014
top left of the keyboard, about the delete (backspace) key
Apple MacBook PC... | Answered on Jul 17, 2014
What is wrong? Did you forget your password? Or the login name? or did you have a crash? Did you reinstall something? Or did a "funny" guy just change your password and forgot to tell you?
Don't panic, Apple should be able to help you if you have an apple account, and you have that password.
Apple MacBook PC... | Answered on Jun 26, 2014
Make sure that the power cord is plugged into a working outlet, that the prong section is connected with a clean contact to the brick, that the magsafe connector and port are both clean. Remove the battery. Now power on the laptop with the power button.
If this does not work, attempt to reset the NVRAM (http://support.apple.com/kb/HT1379). If this is still not working, you can disassemble the machine and remove the upper part of the bottom case (lifting the keyboard section, and try to reseat the keyboard connection to the logic board. This cable is what allows the power button to turn on the machine. If this fails to fix it, then you have either a bad i/o board, or a bad system board, or a bad power cord.
Apple MacBook PC... | Answered on Nov 13, 2012
Apple MacBook PC Notebook Logo
164 questions posted
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
graphic display partially missing
  • Computers & Internet
