I have my tension set at 0. If I go higher it is worse.
Does this machine have adjustable pressure settings for the presser foot ? If it does, reduce the pressure. The softness and bulk of fleece makes it tend to bunch, so less pressure is very helpful. A wide presser foot with a very flat bottom may also help.
Reduced presser foot pressure is helpful for most knits, very much so for stretchy fabrics. Fleeces are usually knits.
Using a stretch stitch also helps. If you don't have a stretch stitch, a very small zig zag is helpful to provide some give to the seam.
Set the stitches for longer length, normal stitch length is too tight for the fabric to move easily. This is also something to do with Jean material.
