Question about Frigidaire Affinity ATF7000E Front Load Washer
HI!I could really use your help. I have a Frigidaire affinity and I was trying to do a clean cycle and pushed the wrong buttons. Since then it's been stuck in loc mode, but it's not lo
I'm not sure on the product. The model is FAFW3801LW3
  • David Duggan
    David Duggan Dec 21, 2014
    Hi Debbie Yancey, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
6ya staff
SOURCE:
prem mathew
  • 1294 Answers
SOURCE: "Loc" error message
nice
Posted on Mar 20, 2008
Anonymous
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
Anonymous
SOURCE: Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
Anonymous
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
oilman_20
SOURCE: My Frigidaire Affinity washing machine says it
my affinty washer is stuck in pause mode
Posted on May 02, 2010
I need a manual for a Cooks toaster convection Rotisserie Oven model 780-2226
Contact Haier direct. The manual is not available online from another source.
Product Manuals and Downloads ' Haier America
https://www.haieramerica.com/support/product-manuals-and-downloadsFind your product manual by category. ... At Haier, we want to make sure that your purchase serves you well. Please contact our Product Support Experts for ...
manual Haier Cooks toaster Oven model 780 2226 Google Search
Nov 20, 2017 | Toaster Ovens
Error code E75 in al frigidair affinity FAFW3801Lw3. What I need to do? help please. Thanks!!!!
E75 has nothing to do with the spin cycle, pump, door switch, or anything like that. E75 means there is an issue with your temperature sensor circuit. That is part of your control board, which means that the control board will need to be ordered and replaced to fix the E75 error code.
Nov 21, 2015 | Televison & Video
How do I run a diagnostic test on a Frigidaire affinity washer model# FAFW3801LW3 I have tried a few different ways and nothing works
I truly (truly) have sympathy for people with computerized appliances. No ''DIY'' situation. Either computer is bad... or worse, the computer is _part of_ the motor, and the cost to replace is same as new machine. (I despise this consumer scamming situation, because it is _designed_ to prevent ''DIY'').
Aug 15, 2015 | Frigidaire Washing Machines
Where is drain filter on infinity model fafw3801lw3 and how do I get to it? Thanks.
Good Morning Dennis, thanks for your post!
From the information you have provided you need to locate your drain filter on your Frigidaire washer. The drain filter is right in front of your drain pump and in order to access it you would need to disassemble your washer. This is not a simple DIY job and I would recommend having a professional technician out to avoid any personal injury. I hope this information is helpful for you. -Matt
Jun 10, 2015 | Frigidaire Washing Machines
I have an Affinity Washer model #FAFW3801LW3 I need to change baffle in the tub. Do the screws line up so I don't have to take the outer tub off to remove baffle
I appreciate your post, Doug!
I see that you need to change the baffle in the tub of your Frigidaire washer, FAFW3801LW3, and you would like to know if the screws line up. Based off the parts manual it appears that the screws line up. I have included a a copy of your parts manual for you to review. I hope this information is helpful to you. -Matt
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=FAFW3801LW3+&User=&Search=Search
May 23, 2015 | Frigidaire Washing Machines
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Frigidaire fafw3801lw3 gives an e5e code
Good Morning Eric, this is JK. I understand that you are receiving error E5E on your dishwasher. It appears the error code you are receiving indicates there may be a communication problem. Check the wiring between the Main Control Board and the Speed Control Board. If you find the wiring is good, you may need to replace the Main Control Board. If the problem is not corrected, consider replacing the Speed Control Board. Hope this helps!
Apr 16, 2014 | Frigidaire Washing Machines
FAFW3801LW3 has error e59
Hi Rosie,
I understand that you're receiving an E59 error code on your Frigidaire washer, model# FAFW3801LW3 and are looking how to run the diagnostic test. While there isn't too much information about actually running the diagnosis, I would recommend contacting the manufacturer and seeing if they are able to assist.
-Best Regards-
Jan 23, 2014 | Frigidaire FAFW3801LW Front Load Washer...
MY FRIDGIDAIRE AFFINITY KEEPS PAUSING DURING CYLES DOSENT MATTER WHAT CYCLE I CHOOSE. IT STOPS ATLEAST 5 TIMES PER CYCLE AND SOMETIME WONT FINISH THE CYCLE. MODEL NUMBER FAFW3801LW3
Hi Brooke, thank you for allowing me to assist you!
Often this happens because the washer door is not securely latch or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, try reprogramming the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. If issue persists, then more than likely the unit has a faulty door latch, a communication error with the control board, or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Best regards!
Oct 30, 2013 | Frigidaire Affinity ATF7000E Front Load...
Need instruction book for hamilton drink mixer model 33
Use and Care Guide for Hamilton Beach products are available here:
http://www.hamiltonbeach.com/use-and-care/use-and-care.php
Are you sure about your model number? Did not find a model 33 in the list but you may be able to find a guide for a similar product.
Feb 01, 2011 | Microwave Ovens
Frigidaire Affinity ATF7000E Front Load Washer Logo
261 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
