20 Most Recent
Frigidaire Fafs4474lw Affinity 3.81 Cu Ft DOE 4.4 Cu Ft Front Lo Questions & Answers
Clean tub options keeps blinking on affinity frigidaire fafs4474lwo model
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
·Rotate cycle knob to Rinse & Spin
·Then press the CLEAN WASHER option button
·The LCD screen will display "SYSTEM CLEAN"
Hope this helps! - Z
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
- Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
- Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help.
I hope this is useful.
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Dryer Squeak, Tight Drum, Burning Smell
The loud, constant squeak/squeal from your Frigidaire dryer, combined with a burning smell, indicates a serious problem that needs to be addressed. While replacing the drum bearing kit was a good step, it appears that there may be other issues at play.
One possible cause of the squeaking could be a worn or damaged drive belt or idler pulley. If the idler pulley spring came off, it is possible that the belt is not properly tensioned and may be slipping or rubbing against the drum, causing the squeaking noise. Additionally, a slipping belt can generate a burning smell as it heats up from the friction.
Another possible cause of the burning smell could be a malfunctioning heating element, which may be overheating the dryer and causing the burning odor.
It is recommended that you stop using the dryer immediately and unplug it from the power source. It is not safe to continue using a dryer that is producing a burning smell.
I have a Frigidaire Dryer and the outside of dryer It was hot to the touch and hadn't been used in couple days ?
f the outside of your Frigidaire dryer is hot to the touch and the heating element appears to be glowing red hot when the knob is not in the off position, it is likely that there is a problem with the dryer's heating element. It could be shorted, burnt, or damaged in some other way.
It is also possible that there is a problem with the dryer's thermostat, which regulates the temperature inside the dryer. If the thermostat is not functioning properly, it could cause the heating element to stay on for too long and overheat the dryer.
It is recommended that you stop using the dryer immediately and unplug it from the power source. It is not safe to continue using a dryer that is overheating or has a malfunctioning heating element. It is best to have a qualified technician inspec
I have a Frigidaire Window AC Heater combo the cooling works but the heat does not blow hot?
It sounds like you may be experiencing issues with the heating element on your Frigidaire window AC/Heater combo unit. Here are a few things you can try to troubleshoot the problem:
- Check the thermostat: Make sure that the thermostat is set to "Heat" and that the temperature is set to a level high enough to activate the heating element.
- Check the air filter: A dirty air filter can restrict airflow and prevent the heating element from functioning properly. Clean or replace the air filter if necessary.
- Check the heating element: The heating element may be faulty and needs to be replaced. Consult the manufacturer's manual or contact the manufacturer's customer service for further assistance.
- Check the blower motor: The blower motor may be malfunctioning and needs to be replaced by a professional technician.
- Check the wiring: Check the wiring and connections, ensure that all the wiring is securely connected and that there is no damage to the wires.
- Check the fuses: Make sure that all the fuses are working properly and that they are not blown or tripped.
Keep in mind that attempting to repair an AC/Heater unit can be dangerous if you are not familiar with the proper procedures and safety precautions. It's best to let a professional technician handle the repair.
If the problem persists, it's recommended to contact the manufacturer's customer service or a professional technician for further assistance. They can inspect the unit and determine the cause of the problem and provide a solution.
Regenerate response
Frigidaire dryer showing the world"loc" & won't start
The control panel lock is engaged. This keeps the dryer from being turned on by accident while cleaning the panel (or by a small child). There should be a line with a padlock symbol between two buttons on the control panel indicating the ones to press and hold to toggle the lock feature. On some Frigidaire dryers, the buttons to press and hold are Options and Select. You need to hold the buttons for 10+ seconds. The LOC message should disappear when you have held the buttons for long enough. However, if you do not release the buttons, the lock will toggle back on.
I hope this helps.
11/14/2022 11:52:05 PM •
Frigidaire...
Answered
on Nov 14, 2022
Electrolux E66 code continuous problem?
Good morning, dissapointed81. I understand that you are experiencing some concerns with your dryer. Before contacting a service provider, I would suggest that you either unplug or turn the circuit breaker off to the unit for five to ten minutes. Let the dryer reset completely and try to use it as normal again. If this does not prove to be effective, we do recommend that a professional technician diagnose the thermal limiter and control board. The E66 error code typically indicates an error within the thermal limiter and interrupted communication to the control board. Though a full repair, and replacement parts, might not be needed we do recommend having a professional test the unit for safety reasons. -Hope this helps!
