CANNOT SEE ANYTHING THAT SAYS MODEL NUMBER, THE ONLY NUMBER WE CAN FIND IS LD0060 HAVE AN ERROR MESSAGE 1E AND DON'T KNOW WHAT IT MEANS SO WE CAN FIX IT
SOURCE: Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
SOURCE: asko 1776 dishwasher error message
open up the underside of the dishwasher and check the 2 terminals that connect to the heater element. Sometimes they burn off and it is a quick repair to just put a new terminal on the end. Also make sure the water going into the dishwasher is hot, as that can cause this problem too. Hope this helps
SOURCE: I have an error code of 1E on my LG dishwasher
1E error is
Not reached to the normal
water level in spite
of 10 min. water supply
POSSIBLE CAUSE REMEDY
FOR ERROR OCCURRENCE
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound.
Remedy
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
SOURCE: What does the error code OE mean on a LG
OE drain Error
Not fully drained out in
spite of 5 min. drain
operation
The Drain Hose kinked or blocked.
Wiring connection is OK?
The drain outlet of sump is
blocked.
The Drain Pump/Motor or circuit is
troubled...
Remove the cause of kink or block.
Check the wiring connection.
Drain Motor. (20-40 )
Replace the Drain Motor or repair
the Circuit
SOURCE: Dishlex 302 model is displating "i30" error which
i ahve the same problem! ANy solutions out there?
