20 Most Recent
Samsung WF8704RSW Questions & Answers
Fix error 1e on Samsung wf875
That's a pressure sensor error. The pressure sensor detects your water level.
If you take the top off of your wash machine, you should see a clear, plastic air tube (like the type used for aquariums) going from your outer tub to a sensor mounted on the top right of the washer (well, I think that's where it is on yours. Your model number isn't anything I have in my records). Remove the air tube from the sensor and blow through the tube to clear any obstructions. Then, put the tube back on the sensor and try to run a wash cycle. If the error code pops up again, change the hose and the sensor. If you still get it, make sure you aren't using too much soap and your drain hose isn't siphoning water from the stand pipe. Because, the next thing you are looking at is a new control board.
10/25/2014 4:21:46 PM •
Samsung...
Answered
on Oct 25, 2014
