When you start it, it make a loud squeeling noise that goes away after 5 minutes
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
SOURCE: KENMORE DRYER
Hello ENRIGHT11
Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND
BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF
YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD
(ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal
of noise coming from the blower area of the dryer when it is running,
then the blower wheel could be defective.
The are many different
designs for blower wheels and just as many unique failure modes. Vanes
(fins) can break off the wheel and bounce around in the blower breaking
more pieces. The blower can break around the coupler with the shaft.
This can cause the blower to spin loosely on the shaft. The blower can
form cracks which cause it to vibrate, etc.
You should also not
be surprised to find foreign debris in the blower. The occasional
bird, rodent or squirrel has been known to bypass the out vent cover.
If they crawl into the exhaust tube the first thing they come into
contact with is the blower wheel.
If the blower wheel is not
spinning, or if it is missing vanes, it is not moving air efficiently.
As a result, heat is not removed from the heat source and it can trip
the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch
and/or become brittle with age. The belt can then slip on the drum or
motor to cause squeaking. If this is the case, the solution is to
replace the worn belt.
The belt is not the only item that can
cause squeaking. It can also be caused by a faulty idler pulley, worn
drum bearings, worn drum glides or worn drum rollers depending on brand
and style.
When replacing the Belt is is a good idea to also change the Drum
Support Rollers, Drum Glides, Idler Pulley and Clips. All of these
items are economical easily changeable when replacing the belt. The
upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some
dryer models are equipped with Drum Glides. The front of the dryer
rests on these glides. They provide a low friction surface on which
the drum spins. After time however, this glides wear down. Much like
an automobile brakes, these glides make a load grinding noise when they
wear thin. This griding against the drum usually leaves a bare metal
stripe that is visible at the point of contact. If the glides are
worn, the solution is to replace them.
The drum glides not
the only items that can cause squeaking. It can also be caused by a
faulty idler pulley, worn drum bearings, a worn belt or worn drum
rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the
Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these
items are economical and easily changeable when replacing the glides.
The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some
dryer models are equiped with a Rear Drum Bearing. The rear of the drum
rests on this bearing. It provides a low friction surface on which the
drum spins. After time however, this bearing will wear down. If the
bearing is worn, the solution is to replace it.
The rear drum
bearing not the only item that can cause squeaking. It can also be
caused by a faulty idler pulley, worn drum glides, a worn belt or worn
drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change
the drum glides, drum support rollers, drum belt, idler pulley and
clips depending on make and model. All of these items are economical and
easily changeable when replacing the rear drum bearing. The upside is
Worn Drum Support Rollers
Some
dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum
Support Rollers. The weight of the dryer drum rests on these rollers.
They provide a low friction surface on which the drum spins when in
operation. After time however, these rollers wear down. When they
wear, often times they begin to elongate and form a non-round 'cam'
shape. The result is that when the dryer is turned on it creates a
rumble that sounds as though you are trying to dry a pair of tennis
shoes. This sound is usually the drum being forced up and down on the
non-round wheels. If the rollers are worn, the solution is to replace
them.
When replacing the Drum Rollers it is a good idea to
also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips.
All of these items are economical and easily changeable when replacing
the glides. The upside is that your dryer will operate like new.
Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
SOURCE: Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
SOURCE: Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
SOURCE: Dryer makes a loud squealing when first started
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Testimonial: "Removed the drum and oiled the various rollers Quieted the noise. Sounds like a new one again. Thanks "
