20 Most Recent Kenmore Elite HE4 Electric Dryer Questions & Answers
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Kenmore Elite... | Answered on Feb 14, 2019
Mr. Clean Magic Eraser will do the trick perfectly.
Kenmore Elite... | Answered on Jan 31, 2019
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Kenmore Elite... | Answered on Dec 09, 2018
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
Kenmore Elite... | Answered on Oct 18, 2018
call an electrician before you kill yourself or burn down the house
Kenmore Elite... | Answered on Feb 20, 2018
there is a clean out to the left or the pump.it should be in the middle front when you remove the bottom panel.[hint] have a shop vac on with the hose next to the clean out so you don't get water every where.if you do not have a wet/dry vac and it is on a pedistal open the drawer and put a small trash can in it.hpoe this helps.
Kenmore Elite... | Answered on Feb 11, 2018
Sounds like your drier is over loaded. Belt slipping due to : to much weight in drier. The drier motor is an adjustable. Belt test: If you can twist belt more than a half a turn it is to lose. Replace belt.
Kenmore Elite... | Answered on Feb 10, 2018
send the model number,open the door look around the opening where you put the clothes in you should see a tag there.if you unplugged it and it worked then it's not any of the t-stats or door switch most likely a board issue or something to do with the cord from moving it,when you unplug it and plug it back in your resetting the board so this is what it sounds like but can't tell if you even have a board without model number.
Kenmore Elite... | Answered on Jan 14, 2018
what's the brand name and model number?
Kenmore Elite... | Answered on Jan 06, 2018
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Kenmore Elite... | Answered on Jan 02, 2018
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Kenmore Elite... | Answered on Nov 03, 2017
Most likely a control issue. Will it come right back on after shutting down or does it need to sit a while?
Contact the mfr. and have them send an authorized technician to repair your refr.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Kenmore Elite... | Answered on Oct 25, 2017
Sounds like the belt that turns the drum could be broken. I'd check that first.
Kenmore Elite... | Answered on Oct 12, 2017
try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Kenmore Elite... | Answered on Oct 06, 2017
Kenmore Elite HE4 Electric Dryer Logo
1,774 questions posted
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
dryer turns but drum will not spin
  • Dryers
