Computers & Internet Logo
A
Anonymous Posted on Sep 27, 2014
Why does my network connection on my powerspec computer keep disconnecting unexpectedly
davidjharper
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Oct 01, 2014
davidjharper
Expert
Level 2:
New Friend:
Answers
101
Questions
Helped
13414
Points
181
Normally this is either because the signal strength from the router is weak, and also if the signal strength is not at its highest then the data can be interrupted by other incidental high power equipment being used nearby. This can be a vacuum cleaner, washing machine etc.
1 Related Answer
Anonymous
  • 167 Answers
  • Posted on Mar 09, 2009
SOURCE: My wireless net work keeps breaking down, I have to restart...
In order to remove the Validating identity to your computer here are the steps that you may need to follow:
- Logon to the configuration page of the router by opening a browser and type in 192.168.0.1 and press Enter.
- Go to Advanced tab and select Wi-Fi Protected Setup at your left side
- Uncheck the Enable box and click on Save Settings located at the top.
Power spec 6342
WinBook PowerSpec 6342 Specifications The specs for PowerSpec 6342 comes in these configurations with a retail price tag. The configuration WinBook provides comes with a 3.06GHz Intel Celeron D 346 n/a Serial ATA, Ultra ATA/133 PCI/AGP 160.0 GB Windows XP Home SP2, S3 Graphics Unichrome PRO 128 MB DDR 128 MB DDR (shared).
This WinBook Computer can take up to 2.0 GB ram, with a fixed amount of 512 MB (removable) installed PC3200 DDR SDRAM DIMMs.
This full-featured mainstream Computer enhances the previous generation WinBook models with the chipsets and new levels of customization. Get the best experience on your WinBook PowerSpec 6342 Computer with improved performance, make it easy to create a home network and share all of your favorite items.
The specs of Computer shows full configuration information. The PowerSpec 6342 is designed for users who require maximum performance in a mainstream Computer. Even with its form factor design, the PowerSpec 6342 doesn't skimp on performance offering the ideal blend of power and efficiency.The PowerSpec 6342 is sure to leave a lasting impression with its easy to use and slim design. Located on the side of the unit, the modular bay's innovative latch is designed for easy insertion and removal of the various module options.
The PowerSpec 6342 Computer only supports 3.06GHz Intel Celeron D 346. The PowerSpec 6342 features two on-board data caches for transferring information to and from the processor. These caches are known as the L1 and L2 caches. The PowerSpec 6342 L1 cache is 64 kilobytes in size, while its L2 cache is rated at either one or two megabytes.
When you have a clear idea of which Computer best suits your needs, check for its specifications. As the PowerSpec 6342 is supported by WinBook, check if the Computer has full support and warranties by its manufacturer, like PowerSpec 6342 specs you will have lots of options from the Computer manufacturer to choose from, like the Computer processor, Computer RAM, its graphics capacity, Computer display options and specs, and other features that the Computer provides. You should have an idea on what specs you want from your Computer and what specs you do not want on your Computer, deciding on Computer specs may be difficult task to do but like the PowerSpec 6342 specs have, it's essential to selecting a Computer you need at a price tag that it deserves and that you can afford.
Here is a sample PowerSpec 6342 Computer specification if you want an initial guide to buy a Computer. More or else, these are the specs factors often that you should take into consideration before you purchase a particular type of Computer. To help you navigate around the hassles of buying a Computer, we have the standard specifications for most home and small business users.
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
Remove a ssd from powerspec g213
there is a grey x shaped knob near the outer casing in the slot your drive is mounted, turn the knob counter clockwise and presto you can remove your dive !!!!!!!!
Manual for Powerspec Computer V100
Hi. Your mainboard is an ECS 945G-M3
Here is the manual for the mainboard:
http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/945G-M3%20(3.0).zip
And the mainboard manufacturer website:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=680&DetailName=Feature&MenuID=1&LanID=0
If you want info about the Tower in general hare is a link to the V100 page on the Powerspec website that will tell you about the components they used to build the system:
http://www.powerspec.com/systems/archives/system_archive.phtml?selection=V100
Hope this helps... Dale
I have epson stylus c88+ printer. just connected
control panel/printers & fax....is your c88 checked as primary printer?
1helpful
Powerspec 8650. what type graphics card fits it? computer keeps shutting down while playing certain games on facebook. extra memory hasn't helped, so i think i need to upgrade my graphics card, just am not...
This card is listed for the model below yours.
Graphics Controller
  • Type AGP 4x - Plug-in card
  • Graphics Processor / Vendor NVIDIA GeForce2 MX 200
  • I would be looking for other causes of shut down such as overheating.
    Check that all fans are working and clean. Ensure all case openings / grilles are also clear.
    If you want to upgrade the vid card you can only get one with AGP 4X
    NOT 8X which most are now.
    My labtop keeps on disconnecting from the internet it says something like unable to connect the preffered wireless network and I dont have any idea why.
    Open "Networks".
    Click "View Available Networks".
    Click your preferred wireless network.
    Click "Disconnect", to prevent your computer, in the future, from connecting to that non-functional network.
    Choose a different network.
    Click "Connect".
    2answers
    If you don't have a contract with ATT, you may want to change. THey have what's called a "sticky static IP" which essentially flickers the connection. This wouldn't typically have any problem with the connection between devices, but some lower end routers and networks have this problem.
    If you don't want to change carriers, try upgrading to another modem. You don't have to have the one they give you. In fact, the netgear and similar ones work well...much better than the 2wires.
    Let me know if this helps.
    My wired pc keeps discconecting from internet
    Check for wire loose connection and then any time setting for your dhcp connection. If they are ok check your network connectivity do as follows.
    Startup
    run
    type cmd
    at the prompt type ping <your router ip address> -t
    kepp watching the reply
    use your computer as normally and check when it gets disconnect by watching above
    may be some corrupted program send packets in an un usual rate (it can be virus/trojan) so the router blocks those port and your computer disconnect from the network.
    Rather from all the above change the PCI Network adapter replace with a new network card.
    Hothawk
    1helpful
    Internet connection
    Here's How:
    1. Click the Start menu button on the Windows taskbar.
    2. Click Run... on this menu.
    3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
    4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
    5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
    6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
    Tips:
    1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
    2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
    Grand Canyon Tech
    Grand Canyon Tech
