20 Most Recent Dell Inspiron E1505 Notebook Questions & Answers
Before you decide to burn a DVD, it is important to know what kind of DVD you would like to burn. The type of DVD will usually determine the process you use to go about burning. The three most common types of DVDs to burn are Data DVD's, Multimedia Files to a DVD and making a copy and burning a commercial DVD. The burning process will be determined by the type of data you want to burn. You could do three possible actions:
  1. Burn Data to a DVD
  2. Burn Multimedia Files to a DVD
  3. Copy and Burn a Commercial DVD
Burning Data to a DVD Ordinary data such as documents, spreadsheets, database files and backup files require only general DVD burning programs. The data that you burn can be viewed on any type of computer with a DVD drive. Popular DVD burning software programs include Nero 9 and Super DVD Creator 9.8.8.
You will need to purchase or download any of the DVD burning software titles that are available on the market. For some computers that are purchased new, DVD burning software already comes installed and configured for your machine and DVD burner. You just need to open up your DVD burner software, choose to burn a data DVD and follow the instructions. You can usually burn a full length DVD (about 4.7 GB of data) in less than 20 minutes and even quicker with high speed DVD burners.
Burning Multimedia Files to a DVD
Multimedia files are usually larger files that include video either recorded from a TV set, camcorder or digital camera or downloaded from the internet. You may also want to convert an old VHS tape to a more user friendly DVD.
Copying and Burning a Commercial DVD
Many people use their DVD burner to burn copies of commercial DVDs. In most parts of the world, it is illegal to copy a commercial DVD and sell or distribute it. However, you may want to make a copy for archiving purposes.
There are many tools that can copy a commercial DVD. However, apart from the normal DVD burner and DVD burning software, you will also need special software that can decode or crack the digital rights management. It is also important to note that besides cracking the code and copying the data of the commercial DVD, you may need to shrink the file.
Most commercial DVDs are dual layer and have between 7 and 8.4 GB of data. These files must be compressed to fit on a normal 4.7 GB DVD. Once you have cracked the commercial DVD and compressed it, you can use ordinary DVD burning software to burn your DVD.
Dell Inspiron... | Answered on May 17, 2019
Hello there brennerc.
Here's your GEEK-steer ...
Based on your description I'm not sure which character that is. Are you sure it's located on a standard keyboard? If not, it's what's known as an "extended" character, with which you'll need your Windows "Character Map" accessory to help you locate.
[Start > Accessories > System Tools > Character Map]
... or ...
[Start > Run... > type "charmap.exe" (without quotes), then Enter]
TIPS:
  • Clicking on any character's (square) will initiate a perpetually zoomed popup to help you see it better.
  • Once you find desired character, double-click (or select button) it to place it into the "characters to copy" field, where you can then "copy" (button) it, and then paste wherever desired.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed – Craig
Dell Inspiron... | Answered on Dec 18, 2017
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Dell Inspiron... | Answered on Nov 03, 2017
If the computer works while it is plugged in the yes by all means buy another battery. If the issue still happens even after it is plugged into the wall then you have board issue which may actually be a power plug issue.
Dell Inspiron... | Answered on Nov 02, 2017
Hi this is della and am expert to solve your issues kindly call us to this number +1(518)348-9393, we are glad to help to resolve your isssues.
Dell Inspiron... | Answered on Oct 06, 2017
Open Device Manager and expand "Network Adaptors"
Check to make sure you have a wireless adaptor shown.
If no wireless adaptor is shown I would suggest you contact Dell Support. When posting for computer assistance it always helps to say what your Operating System is.
Sometimes Windows 10 for example will not recognise hardware designed for earlier OS.
Dell Inspiron... | Answered on Jul 31, 2017
Can you do a system restore? If not, here is something to try:
You may have caused a registry error. Try running a registry repair program, restart the computer after repair has run, then try reinstalling, after reinstalling, restart the system once again, then try DVD. Good luck.
Dell Inspiron... | Answered on Jul 14, 2017
Try it in safe mode with networking.
Dell Inspiron... | Answered on May 30, 2017
A $20 part, the "inverter" inside the LCD case has failed.
Unfortunately for you, a qualified technician will charge you $50 to $75 for "one hour labour"
to disassemble your computer, remove the dead inverter, attach the new one, reassemble your computer, and test that replacing the inverter has solved the problem.
If you have to ask "how to replace the inverter", the best answer is "let a professional do it".
Dell Inspiron... | Answered on Jul 20, 2016
Hello, Pull the battery from the laptop and see if it will powerup without the battery in. If not the charger is bad, if it does then the battery is bad.
Dell Inspiron... | Answered on Nov 02, 2015
Hello here is a battery you can use.It has to have the correct amount of amps for the battery to work on the laptop. At least 7200 ma.
i have another laptop that is saying this computer system #5zp7yj1-595b is protected by a password authentication system.you can not access the data without the correct password can u help please as i dont know the password
Dell Inspiron... | Answered on Feb 24, 2015
you are loging in with the incorrect password.
Dell Inspiron... | Answered on Jan 26, 2015
system restore back a few days before this happened. hope this helps.
Dell Inspiron... | Answered on Jan 11, 2015
Check the charger for output voltage at the plug.
Dell Inspiron... | Answered on Aug 24, 2014
Hi
I know this may be obvious but have you checked that you have not muted all of the sound in the control panel sound app
Cliff Cook
MCP
Dell Inspiron... | Answered on Aug 03, 2014
you will require windows cd to reset or remove the password,first boot with cd and you get option to press any key to boot with cd ,press any key now windows will start copying files ,dont worry we are not reinstalling windows so keep up the installation process till you get the screen which says installing devices and windows time will be approx. 39 minutes to complete installation
quickly press Shift key+F10 this combination will stop windows installation and new window will pop that gives you option to reset and remove password.
Now do as you like and remove windows cd ,
It is the best possible solution you may find in all of cyberspace ,no harm to computer is done ,i hope you will be happy to use this technique and help others as well.
thanks and regards
kindly rate this solutions
Dell Inspiron... | Answered on Jul 17, 2014
I hope this can help you.last month my sister had the same problem,and then we solved it as follow: There is a way to reset the password and it doesn't involve reformatting and reinstalling Windows. The solution is called "Windows Password Key 8.0". It is the most popular and safe solution for resetting your Windows password until now. You can down it from: http://www.lostwindowspassword.com
Dell Inspiron... | Answered on Jul 16, 2014
It is unfortunate that the computer is giving 2000-0142 error, you may want to try running the hardware diagnostics again and provide me the Validation code along with the error code. Then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell Inspiron... | Answered on Jun 28, 2014
Dell Inspiron E1505 Notebook Logo
839 questions posted
Ekse
Clive
Clive
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
lost password installing drivers lw
  • Computers & Internet
