20 Most Recent
D-Link Xtreme N DIR-655 Wireless Router Questions & Answers
MAC Book Pro unable to connect the wi-fi. Connection timed out er
Reset your wireless password/key. Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
DIR-655 randomly drops connection
I would look to see if there are any nearby wireless networks residing on the same or adjacent channel. If so, change the channel the router is broadcasting the network on as this can easily cause the types of issues you are describing.
I have a D-link DIR-655
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Lost dlink dir 655 password
Default user is Admin and default password is blank. (Don't type anything)
If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults. To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
http://www.scribd.com/doc/6254595/DLink-Dir655-Manual-Wireless-N-Router
I have hughes net with
Make sure you use the correct cable between the router and the D-Link. If you use the blue wire it won't work. The orange and orange white pair have to be swapped with the green- green/white pair on one end of the cable only. Usually, the cable is orange in color and is called a crossover cable.
Dlink router with hughesnet
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
Using DIR-655 as hub, DHCP disabled, 3 PCs
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
My internet company (Americable) suggested
Login into you router using your browser (connected by a LAN cable) and under the wireless section you should see the network password.
My DLink DIR-655 Wireless N
Try rebooting the router. Does your laptop "drop out" when connected to other networks?
Orange globe keeps appearing on my dlink dir655 and it disconnects internet
First try replacing your LAN cable between you internet modem and the router. A bad cable the is intermittent may cause this issue. Try rebooting the modem. Also if possible try a direct connection to your internet modem by LAN cable or wireless and see if your connection stays up. You could have a bad internet modem or other connection issue from your provider
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset.
