SOURCE: f06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
SOURCE: What does the F06 code
Hi, this advice is for Kenmore Elite HE and Whirlpool Duet FRONT LOADER washing machines displaying the "F06" error code.The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness.Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor.Perform a continuity check of the Drive Motor windings.Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3.All readings should be approximately 6 ohms.HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3.If the readings are good, this will also prove the wiring and connector good.
- Check the MCU.The connectors are numbered 1 to 3 (L to R).That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires.At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor.Pins 1, 2, and 3 on this connector are the Drive Motor windings.Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector.Pins 1 to 2 should read 120VAC with the door in the locked position.Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE:All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
SOURCE: Whirlpool duet washer-error F06 and E02
Unfortunately F06 E02 is a very bad error. It means you have an interface communication error. That means that the main control board isn't communicating with the front interface control board. You can pull the washer out and remove the 3 screws coming in from the back of the top panel. Next, the top panel will pull straight back, up, and off. Now check all the wire connections between the two control board and make sure they are all secure. If everything looks good, then the interface control board will need to be ordered and replaced.
Here is a link to the part.
