Replaced defrost heater & assembly, defrost thermostat, evaporator thermistor & freezer thermistor. Completely defrosted unit before restart.
GE refrigerators use a board to control cooling and defrost functions. The fresh food compartment also utilizes a motorized damper, and some models even have a fresh food fan. Air enters the fresh food compartment at the top left corner, and the return air is also in the left wall down near the crispers. Both paths must be clear.
SOURCE: Fresh food side is warm, evaporator coil is iced, whirlpool
There is a defrost timer that can be turned by a screwdriver until it clicks wait about 20 mins to see if advances if not, turn it some more to turn on ref and the timer is bad
SOURCE: GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Testimonial: "Thanks for confirming my suspicions. "
