20 Most Recent Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Questions & Answers
Freezer door won't slide open
A tightly frozen door could take days to unfreeze inside. Try using a hair dryer around the door seal. It will take awhile to unfreeze the door this way but it is quicker than waiting for it to defrost. You may have had an extreme leak. Turn the water off to the freezer and turn the freezer controls off or set to zero. You are in a pickle! This is not going to be a quick fix.
11/22/2017 3:21:16 PM • Amana ABB2224DEW... • Answered on Nov 22, 2017
0answers
Refrigerator freezing food. Bottom freezer works ok.
Amana ABB2222FE There is your user manual :) Its the first one on that link.
3/11/2014 4:06:58 AM • Amana ABB2224DEW... • Answered on Mar 11, 2014
2answers
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
1/6/2014 3:45:55 AM • Amana ABB2224DEW... • Answered on Jan 06, 2014
2answers
Fridge and freezer stopped working.Power still on
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
3/8/2013 8:15:48 PM • Amana ABB2224DEW... • Answered on Mar 08, 2013
Ice maker not working
The first thing I would check is the FILL Sensor. It usually is a Wire or Paddle device that sits above the ice. Most of them you can manually move up to a locked position that shuts off the ice machine.Also, some machines have an OFF switch on the Ice Machine Motor housing.
1/18/2013 12:03:43 AM • Amana ABB2224DEW... • Answered on Jan 18, 2013
ACCESSING DRAIN TUBE ON AMANA BOTTOM MOUNT FREEZER
You pull the drawers out as far as they go then lif up and again pull straight out. That can be found on page 15-16 in the user manual found HERE If you need help I will be here just ask, Thanks Sea Breezearrow_results_summary.gif Get Adobe Acrobat Reader
7/6/2012 3:21:21 AM • Amana ABB2224DEW... • Answered on Jul 06, 2012
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
136 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
amana abb2224dew repairman installed
  • Refrigerators
