The bottom hinge needs slackening off, lift the edge of the door in place and retighten the hinge screws; if it's not that loose, a sharp tap with the heel of your hand may bring it back into line
I know the minimum operating temp for many refrigerators is around 33 F (about a degree above freezing or so). This is due to the refrigerant gas within the compressor and the fact that it is not stable at low temps. Typically, a refrigerator's minimum ambient temp should be 50 degrees F (10 degrees C).
I don't know if there is a whole lot you can do. The refrigerator really wasn't built to work in such cold weather. You may either have to relocate it, put a heat source near it or look into a special freezer that is *supposedly* able to operate in much colder ambient temps.
hi
in this unit it is actually called and adaptive defrost
it is found in the top console
take doown the control center
and then take off the deflector on the side wall
the defrost control is inside the deflector
There is a fan in this refrigerator between the freezer and the fridge and it is possible this fan has stopped or something has stopped it from running.You will need to get it repaired.
CHeck and see how hot the space between you fridge and feezes is and if it's real hot that's your problem.
It's either dirty or maybe a rodent got into this motor and stopped it from running.
also check defrost timer,defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
