20 Most Recent Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Questions & Answers
2answers
Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
11/4/2020 1:59:54 AM • Frigidaire... • Answered on Nov 04, 2020
Clear codes for affinity dryer
Hi Friend, this is Z. I am happy to assist you! I see that you have a Frigidaire Affinity dryer and I'm presuming you are seeking information on how to clear error codes on your dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can help pinpoint the exact problem. In the meantime, you can reset your dryer by either unplugging your dryer or flipping off the breaker for roughly ten minutes. This often clears most false error codes. Hope this helps!
8/30/2016 3:49:46 PM • Frigidaire... • Answered on Aug 30, 2016
Stop after star and the drying , cool down and etemded bumdle ares blinking
Hello Louis, thank you for your post! From my understanding your Frigidaire dryer is stopping and multiple lights are blinking. I would suggest performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. If that does not help resolve your issue it could be a possible problem with your control panel or a wiring harness within the dryer. You may need to seek additional assistance from a professional technician for a complete diagnosis to be completed. Best of luck! -Matt
3/29/2016 8:10:15 PM • Frigidaire... • Answered on Mar 29, 2016
Just replaced heating element put all back together turned on, immediately turned off won't turn back on
Hello friend, thank you for your post! Based off the information you have provided you have replaced the element on your Frigidaire dryer and now it will not power on. You could need to have your control panel, wiring harness, or power cord replaced. Since it could be anyone of these underlying issues I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help prevent you from purchasing any unnecessary parts. Hopefully this information is helpful. -Matt
3/10/2016 3:22:29 PM • Frigidaire... • Answered on Mar 10, 2016
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post! From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
2/10/2016 1:54:52 PM • Frigidaire... • Answered on Feb 10, 2016
Frigedaire affinity dryer will not start
Not familiar with this one but it has to check door switch and most have a thermal fuse (start fuse) located near or on the blower wheel that goes bad. Check with ohm meter.
8/5/2015 2:23:31 PM • Frigidaire... • Answered on Aug 05, 2015
Starting my dryer and I see LOC On my settings. It won't start. What is the problem
It is a child lock code press Select and Option buttons at the same time that will help you to toggle between on and off check you owner manual to be absolutely sure Worse case is to change the control board which can be done after unplugging your unit and removing two screw on the back will remove the top panel
7/25/2015 1:24:20 PM • Frigidaire... • Answered on Jul 25, 2015
2answers
What is error code E64 and how can it be fix
Good Afternoon Friend, this is Z. Thank you for your inquiry! Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
5/11/2015 7:47:52 PM • Frigidaire... • Answered on May 11, 2015
Where are my dryer fuses located on my fridgidaire affinity front load
on the heater and blower housing
4/22/2015 10:59:28 PM • Frigidaire... • Answered on Apr 22, 2015
Error code e 91 for frigadare affinity dryer
most likely faulty control board........... cheers
4/5/2015 10:57:31 PM • Frigidaire... • Answered on Apr 05, 2015
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
3/1/2015 2:46:39 AM • Frigidaire... • Answered on Mar 01, 2015
Have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
2/10/2015 12:14:50 AM • Frigidaire... • Answered on Feb 10, 2015
How/where can I find an error code on my Frigidaire Affinity electric dryer?
online owners manual,what is it doing?
1/2/2015 9:48:35 PM • Frigidaire... • Answered on Jan 02, 2015
2answers
How can i fix an e64 code for frigidare affinity dryer
Good Afternoon Friend, I understand you are receiving an E64 code on your Frigidaire Affinity dryer. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number, so I am able to better assist. Hope this is helpful. -Best Regards- WP
11/22/2014 6:18:13 PM • Frigidaire... • Answered on Nov 22, 2014
How do i change the fuse on my Affinity dryer?
Thermistor or high limit switch has tripped; usually due to low air flow from lint build-up or vent blockage. OR, the heating element went bad and a new one can be ordered. In some cases, I have received new thermal switches with the element. It's a job getting the dryer apart and inspecting the element, but you need to know for sure before you have a fire or a control board failure.
7/18/2014 4:42:13 AM • Frigidaire... • Answered on Jul 18, 2014
Error E063
Good Morning Friend, I understand you are receiving an E63 code on your Frigidaire Affinity dryer and want to know what it means. The E63 code means that there is possibly something going on with the heating element or some wiring inside your dryer. This can also be a false code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
7/11/2014 1:42:37 PM • Frigidaire... • Answered on Jul 11, 2014
Frigidaire affinity electric dryer says error E 64, what does that mean?
Heater has an open circuit and need to be replaced. Here is the part you need.
7/4/2014 5:23:51 PM • Frigidaire... • Answered on Jul 04, 2014
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
Popular Tags
139 questions posted
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
error code e64 fix
  • Dryers
