Good Afternoon Friend, I understand you want to know how to replace the door on your Frigidaire range. I will be more than happy to assist you. So I am able to better assist, I ask that you please leave me the model number of your appliance. Typically, you can find this number on the back of the door or possibly in the bottom drawer. Looking forward to hearing from you. -WP-Good Afternoon Friend, I understand you want to know how to replace the door on your Frigidaire range. I will be more than happy to assist you. So I am able to better assist, I ask that you please leave me the model number of your appliance. Typically, you can find this number on the back of the door or possibly in the bottom drawer. Looking forward to hearing from you. -WP-
You can't post conmments that contain an email address.
? 4:32 https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
? 2:12 https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
An oven door repair may be needed if the door
hinge breaks or is bent out of shape. Oven doors have two door hinges, a
left and right. On some ovens the same hinge is used, on other ovens
the right hinge and left hinge have different part numbers. The door
hinge sometimes is sold with all necessary parts and springs, other
times the parts need to be ordered separately. An oven door repair for a
door hinge is a relatively easy repair for a do-it-yourselfer.
If the outer door glass is broken, it can be
replaced. This oven door repair requires that the oven door be removed
from the oven and layed down on a sturdy flat surface. The outer door
glass is made of tempered glass. Use eye and hand protection when
performing this oven door repair.
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
TheseVideos will
help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at
our website
1how to remove your oven door for cleaning
or repairs and how to reseat the door when finished.
2How to change and fit oven door hinges.
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above.
To lock the control panel and both oven doors:
Press and release Cancel.
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Please see this link for more information as how to disengage the lock on your Jenn Air Oven---
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked. To lock the control panel and both oven doors:
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
