Electronics - Others Logo
Posted on Jun 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transcend 2gb pen drive file copying problem
When i try to copy any file from PC to pen drive,it takes lot of time for very small files also.but copying from pen drive to PC is working fine.can any one help me?
laikexpert
Level 3:
President:
  • Master 281 Answers
  • Posted on Feb 08, 2010
laikexpert
Master
Level 3:
President:
Answers
281
Questions
0
Helped
272341
Points
1232
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
1helpful
I have transcend JF V30/4GB pen drive. Recently i am getting in the pen drive that i cannot do any format in the pen drive nor i cannot copy/delete the files in the pen drive. it was showing that...
Hello and Welcome to FixYa!
Kindly try this solution:
  • Connect the USB stick to another computer and copy all the data.
  • Download this file (click here) to that PC and format the USB stick using this program.
  • Now try to connect the USB stick to your ACER laptop and see if it works.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
My laptop is reading the pen drive, opening and operating all files but i'm not able to transfer any file to pen drive, although i can transfer files from pendrive to desktop. kindly provide the solution...
if there is no security password or write protect switch (this would be a small switch on the side of the pen drive) then it may be your pc not allowing cut and paste transfer. Try right-clicking on the file you wish to move to the pen drive, click "copy" then right click the pen drive icon and click"paste" this would copy the file to the drive instead of moving it. Moving the file is effectively, copying it to the drive and deleting the origional and if the origional has password or other forms of increased security/priority the pc won't allow it to be deleted or moved.
good luck.
1helpful
2answers
Unable to transfer files to sony 4gb pen drive
Restart your PC and try it again or try it on other PCs. If problem persists then pen drive is defective. Return to retailer and ask for a replacement.
1helpful
2answers
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
1helpful
2answers
Write protected
write protected i am not able to copy nor delete files from my 4gb transcend memory card
2helpful
2answers
Cann't transfer data through pen drive and cann't copy data
can not copy to pen drive& vice versa.And then can not Format.when Formating,it shown "this volume is write protected".what can I do...help me ..my cell no..9025274371...
211helpful
17answers
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
