20 Most Recent Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive Questions & Answers
How to use a dane-elec 32gb
When you plug the drive in, your computer will set it up as another hard drive available for your use. You can open Windows Explorer and drag the drive icon to your desktop to recreate the icon. Or just use Windows Explorer (not Internet Explorer) to access the drive.
3/14/2014 3:16:55 PM • Transcend 32GB... • Answered on Mar 14, 2014
Usb is recognised but cannot be opened
There are a number of online USB repair options (JetFlash Online Recovery at Transcend website is one) but I have also had some luck repairing balky USB sticks by simply deleting the current partition and creating a new volume using : Windows Control Panel -> Administrative Tools -> Computer Management -> Disk Management. Good Luck!
11/10/2013 1:49:12 PM • Transcend 32GB... • Answered on Nov 10, 2013
3answers
Write - protected message when I connect my Transcend 8GB Pendriv
write protection on transcend 16gb pen drive
8/8/2013 6:09:39 AM • Transcend 32GB... • Answered on Aug 08, 2013
Hai..my transcend 256 mb pen drive is not opening
Hi the problem u are facing right now in ur pen drive is due to virus infection in ur pen drive. Whenever u insert ur pen drive to a pc it will ask for this"Disk is not formeted & do u want to format it" option.. To solve this problem format ur pen drive by right clicking and selecting format option or scan ur pen drive with updated version of antivirus...
thank u
6/23/2013 8:57:07 PM • Transcend 32GB... • Answered on Jun 23, 2013
Windows cannot read from the disk. the disk might be corrupted
Try reformating the drive. It could just be bad sectors in a crucial area, ssd's are pretty stable unless exposed to static electricity or water. Or someone who went willynilly deleting things and unplugging it while perfoprming a task.
10/8/2012 7:26:14 AM • Transcend 32GB... • Answered on Oct 08, 2012
I have a 8gb UltraSpeed
I think you should try this out(In your windows operating system lyk.WIN 7) follow the steps:- 1. plug in your flash drive 2. ON DESKTOP OF YOUR COMPUTER OR LAPTOP 3. right click on my computer > then click on manage option 4. THEN A NEW WINDOW(computer management) WILL BE OPENED 5. then choose DISK MANAGEMENT in storage 6. then you'll see your hard disk partition and a separate partition of your 8GB flash drive 7. that (8gb partition will be unallocated) 8. right click on that partition(unallocated one) 9. then create a simple new volume..... by following these steps you'll be able to fix your problem HAVE A NICE DAY
9/30/2011 6:42:26 PM • Transcend 32GB... • Answered on Sep 30, 2011
2answers
Bad perfomance
my 32 gb not warking
9/29/2011 1:46:52 PM • Transcend 32GB... • Answered on Sep 29, 2011
2answers
My pendrive transcend jf v30/321 gb not store any
There are several possibilities:
1. Damage to the partition table. If there is damage to the partition table, use the JetFlash OnlineRecovery software. This software can be used to repair a flash drive and keep existing data. Repair flash drive RAW format, used space 0 bytes, free space 0 bytes, can't format, repair partition table, repair firmware, update firmware, and keep exiting data.
2. Flash drive bad sectors. To check for bad sectors, use the HD Tune software. The way: insert a flash drive, open the HD Tune software, select the drive, error scans, and Start. Picture.
If you find bad sectors in the flash drive, the solution: backup data, use software HDD Low Level Format Tools. Open HDD Low Level Format tools - select drive - continue - click SMART - Get SMART Attribuutes - click Low Level Format - Format This Device - Yes - wait until the end - OK. After the finish, remove the flash drive from the computer. Then enter again. Then format the flash drive and finish. Picture
Transcend
to repair bad sector, you can see in the video.
9/24/2011 6:14:55 AM • Transcend 32GB... • Answered on Sep 24, 2011
My name is vishnu.my 32gb(760557817543)pendrive
is your transcend express card or a pendrive not working
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
8/9/2011 7:17:44 PM • Transcend 32GB... • Answered on Aug 09, 2011
32 GB transcend express card
You need to find out if this is caused by a formatting failure or the memory chips inside it have started to fail.
For that install this program http://www.partition-tool.com/personal.htm , connect the card and start the program - in it will be displayed all the disks with all the partitions in them, the card will be the last. If the card is listed at 1.9GB then this is what it has now, the other chips holding the remaining space have failed = the card is dead, just junk it.
If the card is listed at full 32 GB (or very close) then the rest of the space will be either free or taken by another corrupted partition - wipe it out then expand the small 1.9 GB partition to fill the entire disk. If you don't know how to do that just use the help section of the program to do it correctly.
7/21/2011 12:11:40 PM • Transcend 32GB... • Answered on Jul 21, 2011
2answers
Cannot format with windows 7
Welcome to Fixya. You can use the HP USB Disk/Drive Format Utility is a Windows based software used to format drives to FAT, FAT32 and NTFS partition types.
1. Download
2. Format pen drive
3. (Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
If you have questions please let me know. Thanks for using Fixya
5/17/2011 7:21:43 PM • Transcend 32GB... • Answered on May 17, 2011
My 32 gb usb does
my transcend jf v30 /32gb is not warking
4/22/2011 5:34:25 AM • Transcend 32GB... • Answered on Apr 22, 2011
My 32g flash drive keeps
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb drive but its not working ports(com&lpt)right click update driver check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall hope this helps don
3/14/2011 2:14:53 PM • Transcend 32GB... • Answered on Mar 14, 2011
TS32GSSD34E-M didn't seen by computer
this sounds like a fake card, did you buy from ebay or china? its a cheap 2gb card with a different label on it.
1/20/2011 11:09:37 AM • Transcend 32GB... • Answered on Jan 20, 2011
I hv a 4 gb
If you choose the 'FAT32' (not the 'NTFS') formatting-option,
and the disk-formatting did not complete, then you have a problem with the 4GB Kingston. Spend $12 to buy a new 4GB device.
11/2/2010 6:06:04 AM • Transcend 32GB... • Answered on Nov 02, 2010
Why 32GB micro sd tf memory card only US$98.00?
I believe this company is located in China. Their website states that their products aren't brand name. My advice, buyer beware.
9/16/2010 4:19:40 AM • Transcend 32GB... • Answered on Sep 16, 2010
2answers
I have an 8gb Ultra Speed USB drive with these
I had the same problem, this worked for me even tho it is not their product.
http://www.transcendusa.com/Products/online_recovery_2.asp?dw=1
8/13/2010 10:54:09 PM • Transcend 32GB... • Answered on Aug 13, 2010
2answers
Windows cannot read from this disk. the disk might be corrupted,o
i have a new CD ok ..but when i tried to copy some files i got a big shock > ( Windows cannot read from this disk. the disk might be corrupted) i dont know why ? even the CD cant open ..i think we should find a programe it can fix our problem
3/14/2010 1:16:43 PM • Transcend 32GB... • Answered on Mar 14, 2010
To Replace Transcend Pendrives
Best to contact your dealer.
2/5/2010 5:23:19 PM • Transcend 32GB... • Answered on Feb 05, 2010
Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive Logo
Popular Tags
53 questions posted
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
k24674
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Transcend Computers & Internet
Most Popular Question
8gb ultraspeed
  • Computers & Internet
