That is because there is a problem with your pump. you need to take the bottom panel off and untwist the pump filter if it has gone further you need to take the 3 screws out of the pump and clean the impeller. try cleaning the pump filter first though and let me know how it goes
f20 is a water problem,shut off the house water valve,mark the hoses and remove them from the back of washer,stick them into the washer or a bucket and open the valve,if water comes out strong then you have a bad water valve on the washer part WP8540751
? 8:30 https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out. the machine probably has a cold only final rinse so it won't work properly.
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Hi!!! You best been usin he detergent if not you are in trouble..You have a sud built up..clean all the water out and go to sears and buy whirlout for he machine..tell them that you have suds and want to clean it with whirout..good luck..
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
