Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor Speed Controller Board Fh-3545c-pw-n Logo
A
Anonymous Posted on May 18, 2014
Tx5.0rc won't start displays 7 only - Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor Speed Controller Board Fh-3545c-pw-n
Display blinks 7 times won`t start
Error code display try finding switch for door and cleaning water in gauze inside pipe
Sylvania 780 with windows 7 powers on but won't display
My sylvania cl772B turns on and shuts right off. what can I do?
When you push start button nothing happens
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
2answers
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
1999 chevy k2500. changed spark plugs 4 times in 7 months. Runs good for a week then doesn't start. Changed spider, throttle body sensor. Still has no codes and once again won't start.
The next time it won't start ,pull a sparkplug wire and see if you're getting fire.Then we'll known whether its a ignition or fuel problem and go from there.
My cannon pixma MP150 just won,t print or do anything, it is connected to the computer alright & the computer says that it is connected but it just won,t print or scan, can you please suggest anything...
probably you need to download the driver for windows 7 in the canon website.(www.canon.com.sg) if this doesnt solve your problem check the led and display of your printer. if the led blinks alternately in orange and green it means that your printer needs to be brought to an authorized service center for resetting and diagnostic.
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Top Sportcraft Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
