Canon PIXMA MP600 all-In-One InkJet Printer Logo
Posted on Nov 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Pixma MP600
Error Message 5010. Turning it off and then on no change.
Thanks
Ed
  • ehgioes Nov 05, 2007
    Thank You for your help. My MP600 doesn't have a switch on the
    bottom. Nothing at all. Thanks
    Ed
arben pllana
Level 3:
  • Master 1,006 Answers
  • Posted on Nov 05, 2007
arben pllana
Master
Level 3:
Answers
1006
Questions
0
Helped
518930
Points
2367
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2088
Points
My printer shows error 5010 I am unable scanning, printing. how can I fix it
I have an error message on my Canon PIXMA MP600 which is 5010. What do I do?
Please go to the canon webiste at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click on: Service and support.
Then in the box type error 5010.
Please follow the instructions provided by Canon.
Thanks,
E-ware
2answers
32helpful
2answers
Canon pixma MP600 error code 5010
My Printer is coming up wiht a printer error B200, and i dont know what to do about it.
Error 5010 not plays
The 5010 error is an issue with the scanning bed. The only way to fix this is to replace the scanning unit on the printer. Check with Canon for a repair center nearest you.
Best of luck..
Have a Happy and Safe Holiday Season.
1helpful
Error code 5010 is showing on my printing and i don't know how to fix it.
I pressed the reset button - as recommended for the cartridge to be detected and ..miracle: the cartridge problem vanished as well as the error 5010 message!!!!!!!! I printed a document with no problem...
Hope this has helped you... Thanks...
Error code 5010
Error Code 5010: Canon recommends resetting the machine. Unplug the power cord for 10 seconds. Then press the power button to turn the printer back on. Wait until the device has completed its cycling process before submitting another job request.
After over three years of use, the error code 5010 appears in the window of my Canon MP600. What do I do? Thanks.
After 3 years of use the scan assembly is worn out. The scan assembly can be replaced in a shop. The cost will be nearly $200.00 though.
10helpful
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
1helpful
Error Code 5010
it's the printer version of a blown engine(as in your car)..got a warranty, I hope.
start with printer driver updates here
old marine
old marine
ZJ Limited
ZJ Limited
