I have fargo hdp5000 printers that keep display this errors message. Lm1 headlift err No 217
SOURCE: Problem on card print using Fargo DTC525 Single Side Print model
I think the problem is in the printer definition. Perhaps the software is calling for the output to be duplexed. The printer does not have a duplex installed so it creates the error. On the other hand, if the printer does have the duplex option, then you are looking at a printer problem.
SOURCE: Card Flip Jam Error message
Open the left hand top cover, In between the ribbon rollers you will see a small flipper, ( small piece of metal with a wheel stuck on one end. ) Maually turn this so the grey wheel is on top and white smaller wheel on the bottom.
This ocassional gets jammed and need righting manually.
SOURCE: Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
SOURCE: My hp laserjet P2055d printer
turn printer off cacel first job in print que power on if problem continues could be formatter
