After a few moments of sewing the thread escapes the needle. If I hold the end of the thread it pulls from the spool. Otherwise it just pulls from the excess thread and unthreads itself.
SOURCE: Juki 8300N
Dear Rosemarie,
Make sure you have threaded the machine from right to left, it sounds
like the needle thread is trapped under the lower looper thread and
cannot form a stitch.........start the threading over from scratch like
this:
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any
thread guides on the way, as each one needs to be followed through to
ensure correct tension and thread progression.
Cheerup and Be Happy always
SOURCE: Needle not catching thread
im no expert, just been sewing for many years, i use 2 different juki machines, i suggest looking at the needle, are we sure you have the rite size? 135/ 140? did the needle just get changed? it could be the correct one, but if its in backwards, there isn't a dimple to let the hook behind the thread, to catch it, feel free to call me, 239-895-4845, my name is devin, shop is Quality Auto Trim Inc., ill try to help you over the phone if necessary, good luck
SOURCE: I recently purchased a Juki
perhaps you have the wrong needle or its not in the proper position?
SOURCE: I own a Juki DDL-8300N industrial sewing machine,
Hi, Please accept the solution if it's helpful. Do get back to us for any further query. Thanks for contacting fixya.com
I do understand sometimes the manuals do not give a complete picture. Check out these videos that I have posted bellow. They show how to set it up.
http://vimeo.com/14428186
SOURCE: my juki machine is not pulling the top thread thru causing the needle to unthread itself
Could you explain the problem a bit more. Sounds like a tension problem but it could also be a poor needle/thread match.
